Posted: Fri Dec 31, 2021 7:32 pm Post subject: |
Ray White wrote: | Hi Rick. Please can you check for me that the radiator grille is not actually brass?
You may just be pleasantly surprised. |
Yes it is brass.
Posted: Fri Dec 31, 2021 8:05 pm Post subject: |
Happy New Year!  |
Posted: Fri Jan 14, 2022 12:25 pm Post subject: |
Spent a little time over Christmas and New Year working on the Prefect in the garage. Putting the fuel pump back together took a couple of attempts before it worked correctly off the car, but once it felt like it was operating with sufficient ooomphhhh I re-fitted it. Priming up took a couple of goes as initially it wasn't keen on functioning, but by rigging up a temporary fuel feed to run the engine off, with the pump's outlet disconnected, forced fuel through into the pump.
This and other tinkerings are covered in today's upload: https://youtu.be/SJhXN7ZcUiI
Posted: Sun Jan 16, 2022 7:56 pm Post subject: |
This afternoon was spent underneath the front of the Prefect, scraping & chipping away decades of caked-on mud. Not the best fun in the world but quite satisfying in a way, next little job I think will be to pull the front drums and have a peak inside. It'll also give me an opportunity to replace the rubber dust covers that protect where the brake cables pass through the backplates.
Posted: Fri Feb 11, 2022 10:13 am Post subject: |
Progress continues on the E93A, the front brakes have been checked over and I also got around to replacing the rubber dust boots that fit over the brake cables, where they pass through the backplates. Various parts have been greased, and I also had a crack at knocking out a few dents around the front end.
Recent progress summed-up in today's upload to the OCC Youtube channel:
https://youtu.be/I8elZAk_Y8s
Joined: 14 Oct 2016 Posts: 1761 Location: East Yorkshire
Posted: Fri Feb 11, 2022 12:23 pm Post subject: |
left you some comments, Rick, on you tube.. _________________ Dellow Mk2, 1951 built, reg 1952.
