Advance curves & Advance springs
12jslater
PostPosted: Fri May 06, 2022 11:25 am    Post subject: Advance curves & Advance springs Reply with quote
Could anyone tell me if they have much info on how to chnage the advance curve on my ford anglia (e494a)?
Mine seems to either want to pull like a train at low speed or smooth at high speed but never both even when adjusting the timing countless times, having a distributor with very little wear and NOS springs, tried fitting an extra very weak spring along with both standard ones and this has improved running noticably (smoother and more power) but still not 100%. Usually I can get the timing sorted easily on newer fifties tuff like A30s and minors but cant with this!
Hope to hear back on others thoughts!
Thanks!
consul 57
PostPosted: Fri May 06, 2022 12:00 pm    Post subject: Reply with quote
have you contacted these people?
http://www.distributordoctor.com/
