WP6980
Posted: Mon Nov 21, 2022 11:04 pm Post subject: BA15D LED Headlight Upgrade 6v |
Has anyone used these new headlamp bulbs?
These give a very good light output and are great for night driving, however, I don't think there is much difference between dipped and main beam and I am wondering if I have my wiring incorrect!
I have arranged the wiring such, that when main beam is selected, dipped beam is extinguished and I am wondering if the dipped connection should remain on when moving to main beam?
I have asked the supplier but have not yet heard and don't want to do anything that may damage the lamp.
Has anyone used these and can they share how they wired the lamps to the switch, many thanks. |
Posted: Tue Nov 22, 2022 12:35 am Post subject: |
Hi there. You don't say what car you have.? No matter.
I couldn't say if your headlamp would suffer from excess heat or not but if you have both main beam and dipped on together you would want to use a relay to protect the switch from overload. |
Posted: Tue Nov 22, 2022 6:49 am Post subject: |
WP6980
I suspect the LEDs will overheat if you use both high & low beams together unless there is a great deal of cooling.
LED headlights are prone to produce a great deal of glare but little useful light actually on the road.
What are the beam patterns like? _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Tue Nov 22, 2022 1:27 pm Post subject: |
| MVPeters wrote: | WP6980 LED headlights are prone to produce a great deal of glare but little useful light actually on the road.
What are the beam patterns like? |
I agree they are very good for being seen, but without the correct reflector/lens combination won't throw the light well.
WP6980
Posted: Wed Dec 14, 2022 10:54 pm Post subject: |
The bulbs include a proper lens to provide a focal point, the reflectors can have really rubbish silvering, they don't need it.
The supplier has replied to my query and this is exactly what he said:
When you power the main beam, both the main and dipped beam functions of the LED light. You should see a good difference between the two.
I don't quite understand what he has written as I think it is missing a word or two, but I believe he means that both will function together when on main beam - I have not yet tried it to verify. _________________ Gary Edwards |
Posted: Thu Dec 15, 2022 4:06 am Post subject: |
So the implication is that, on dipped beam, some part of the LED goes out. There must be some circuitry in the LED. It will be interesting to see if you can detect this - use dark glasses!
But are the beam patterns on the road good? _________________ Mike - MVPeters at comcast.net
Posted: Thu Dec 15, 2022 8:52 am Post subject: |
| MVPeters wrote: | | But are the beam patterns on the road good? |
That's the important thing, if they provide a good beam pattern, throwing the light, happy days
WP6980
Posted: Mon Dec 19, 2022 9:10 pm Post subject: |
on the dipped beam position, the road ahead is well lit, even on country roads, so dipped beam is good.
flicking up to main beam, the light beam goes upwards but the output seems to be about the same.
I have not yet had the opportunity to alter the wiring so that the dipped beam stays on irrespective.
I will report back! _________________ Gary Edwards |
