Flashing Idicators question.
PostPosted: Tue Mar 05, 2024 9:20 pm    Post subject: Flashing Idicators question. Reply with quote
As usual, I am probably over thinking this.
My indicator switch has a built in flasher unit. What I don't feel confident about is how it would cope with a relay.
By "cope" I mean if the relay operates the switch with a reduced voltage, would it be enough to operate the flasher unit?
When it comes to a switch, I don't really know if power is 'drawn' or 'pushed' through it.???
PostPosted: Wed Mar 06, 2024 8:29 am    Post subject: Reply with quote
A mechanical switch or relay contact (in good condition) will have negligible voltage drop .
What I'm not clear about is where the "relay" comes in to it, do you have relays after or before the flasher unit?
If its an electronic switch, there would be around a 0.7v volt drop due to the semiconductor forward bias.
PostPosted: Wed Mar 06, 2024 10:13 am    Post subject: Reply with quote
I may have been unclear. The relay question was a hypothetical one. I don't have a relay for the indicators; I just thought for a moment that I might add one while I am wiring them up... but I probably won't need it as both the switch and wiring is new.
So,,the voltage from a relay to a switch is still 12 volts even though there is less current?
PostPosted: Wed Mar 06, 2024 11:01 am    Post subject: Reply with quote
The question doesn't make sense Confused a relay is simply an electrically operated switch, the "output" voltage from a "made" relay "contact" will dependent on what voltage is on the other side of the contact, a 12v relay may be switching 240v mains?
