Posted: Thu Apr 11, 2024 12:16 pm Post subject: |
I have a policy with Autoaid.
As a result of being a dilatory fool, I allowed it to auto renew.
It's now over 80 quid, a lot on a limited pension...Plus, I haven't used it in years now.
I also noted that they had inserted an age limit on vehicles they attend, so I emailed them demanding cessation of my newly acquired policy, because I have either no intention of, or being able to afford to, obtain a much newer vehicle!
So their policy no longer fulfilled my needs, through no fault of mine!
I had always had the same, now 21 year old, vehicle .
I have now received an email informing me that my policy now has an add-on clause allowing me to have cover on ''any age of vehicle''....
I think I still have to find ?25 to pay the driver if I ever break down...in my old Suzuki GV....which I never used to have to do.
What peaves me more is that, on doing a bit of research, I find that the Autoaid sister operation do the vehicle-specific recovery section
Used to be all one, with a choice of vehicle, or policyholder, having the cover.
For my vehicle {age irrelevant } it would cost me under ?30 for recovery cover.....
I am considering whether to suck up the ?15 admin charge to cancel my policy, and take our their vehicle-specific cover instead?
I had policyholder cover originally because I had more than two daily drivers.....each used for a brief spell of time, so I had personal cover instead.
In fact, over the years, I have recovered more vehicles for friends & neighbours than have needed it myself...
Also, I am not afraid of getting my hands dirty & oily, but nowadays struggle to stand up from the kneeling or laying down position... _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Thu Apr 11, 2024 12:17 pm Post subject: |
Joined: 30 Apr 2013 Posts: 3849 Location: The Somerset Levels
Posted: Mon May 06, 2024 2:46 pm Post subject: |
Well, we're all getting over colds here and with the weather set to rain I thought I'd spend the day clearing the garage with a view to getting the 1947 Minx out of storage. She hasn't been on the road in years and tbh I haven't started her in 3-4 years now.
It's also very awkward as she is facing into the garage and the Hillman alligator bonnet needs quite a bit of room to open fully and at present I can't do that. The plan is to today, get her started and turn her round.
Well I spent and hour or two decluttering to give space to move her, then I pushed her out a couple feet so I could open the bonnet. I charged a battery, hand primed her for fuel and checked the oil and water...once the battery was connected I gave her full choke and on her first pull of the started she fired into life, all be it stodgily.
I managed to get her out onto the driveway where I could then pump all the tyres up and I also removed all the hubcaps to check wheel nut tightness. I turned her around and then just as a large downpour started I reversed her back into the garage.
My plan I think is to insure her for the summer and now with my commute only being about 25 mins across the Somerset levels it might be nice to drive her in on sunny days. _________________ Various Rootes Vehicles. |
Joined: 16 Oct 2008 Posts: 1134 Location: Upper Swan, Western Australia
Posted: Fri May 10, 2024 10:33 am Post subject: |
I finally got serious about repairing the Chrysler. I bought a brand new 6 volt coil and a second hand Stromberg OE-1 carby from the Veteran Car Club of WA spares shed.
I washed the carby out with petrol and plenty of air, before fitting it, without touching the idling and main jets (both adjustable). The car started first time and ran well! Not bad for a 100 year old carby that has probably been off a car for decades!
I'm a happy boy again.
1950 Austin A40 tourer
1999 BMW Z3
Joined: 25 May 2011 Posts: 2502 Location: South Cheshire
Posted: Fri May 10, 2024 6:06 pm Post subject: |
I'm still trying to replace rusty steel, holes and "repair panels" made out of what seems to be old oil cans (because of the thickness, or lack thereof, not because there are green and orange lines on them) with actual steel around the rear trailing arm mounts on my project car. _________________ 1976 Vauxhall HP Firenza, 1976 Vauxhall Sportshatch (x2), 1986 Audi coupe quattro, 2000 Audi TT |
Posted: Sat May 11, 2024 6:46 pm Post subject: |
I went out to the farm where we store the big Hillman today. Took off all the sheets, covered in Barn Owl droppings!!
Gave her a good look over, oil, water, plugs etc and pumped up all the tyres. She always needs hand priming as the fuel tank is so far away from the engine. With a fresh battery in place she fired up lovely.
We tool her into Wells, about 25 mins each way so gave her a nice run. _________________ Various Rootes Vehicles. |
Posted: Sun May 12, 2024 12:59 pm Post subject: |
Small but very noticeable oil leak on the top fitting of the oil filter casing on the Commer cured by adding a suitably sized fibre washer.
Then when running her up though I left the choke on full while we wandered away and came back to petrol pouring out the carb...stopped the engine and wiped it all down before starting her again with no choke and she then ran sweet on tickover without any petrol spillage. _________________ Various Rootes Vehicles. |
consul 57
Posted: Tue May 21, 2024 1:11 pm Post subject: |
i had a set of elec ign for my consul for years but have only just got around to fitting it.
i bought a neg earth set so i needed to convert it to neg earth as it was still pos earth.
i must say the difference was impressive, starts easier, ticks over better and the annoying flat spot has disappeared, i have gone through the entire system, plugs, leads, rotor arm & cap as well as adding the elec ign, the main difference is hills, it pulls better and is faster on hills than before and i don't have to change down as often as before.
well worth the conversion.
and before the naysayers warn of them going wrong i bought another module that was cheap on ebay so have the breakdown of that if ever covered as well, my mates zephyr has the same set up and has been fine for 15+ years.
next elec wipers after last saturdays rainy day. |
Posted: Tue May 21, 2024 6:33 pm Post subject: |
Welded up the front lower subframe mount on the project car, and now I must figure out the charging issue on the Sportshatch ready for Tatton Park in a couple of weeks. _________________ 1976 Vauxhall HP Firenza, 1976 Vauxhall Sportshatch (x2), 1986 Audi coupe quattro, 2000 Audi TT |
Posted: Sat May 25, 2024 6:11 pm Post subject: |
I took the car out to get some petrol ready for Tatton Park next weekend, and other than a few seconds before I left the shed, the battery voltage stayed around 13.6 - 14.0 volts through the whole trip. As a reward, I washed the dust off the car, and I'll wax it during the week.
As it's an intermittent fault, I can't say that it's fixed, only that my confidence is growing a little. _________________ 1976 Vauxhall HP Firenza, 1976 Vauxhall Sportshatch (x2), 1986 Audi coupe quattro, 2000 Audi TT |
Posted: Sun May 26, 2024 10:37 am Post subject: |
Took our 1942 Commer to a wartime show quite local to us. It's about 12 miles each way and I must say after a clean of the plugs before setting off she drove lovely. Engine running like a sewing machine as they say..
Lots of sunshine, lots of photos taken and lots of very nice comments from the public.
And I must mention nice to say hello to a local fellow member of the forum Consul 57 ![Wink](images/smiles/icon_wink.gif) _________________ Various Rootes Vehicles. |
consul 57
Posted: Sun May 26, 2024 4:11 pm Post subject: |
yes indeed a very nice day, better than today!
the commer looked great along with the rest of the green machines.
took some pics of the martian to enable me to make one for my range.
nice to speak to you again after 6 years!
we really enjoyed the day, one of the best so far. |
Posted: Sun May 26, 2024 6:11 pm Post subject: |
Having washed the car yesterday, I saw that it was dry this morning so I thought I'd take it to a local gathering. I went the quick way, down the back lanes, to find that someone has spread mud and "stuff" all over one of them, for what seemed like miles but was probably half a mile. I did no more than 10mph through it, but still had to wash the car again when I got home. Went OK, though. _________________ 1976 Vauxhall HP Firenza, 1976 Vauxhall Sportshatch (x2), 1986 Audi coupe quattro, 2000 Audi TT |
consul 57
Posted: Mon May 27, 2024 12:03 pm Post subject: |
we have just done 1/3 rd of the lazy monday run & show, only to find it had been cancelled as the show field was muddy
sad they cancelled, car got a soaking again, oh well. |
