Southernscouse
Joined: 30 May 2024 Posts: 26 Location: Havant Hampshire
Posted: Sat Jun 22, 2024 8:44 pm Post subject: Fuel gauge |
Hi gauge on my Austin Devon van flickers between 1/4and 3/4 as soon as I switch on the ignition while driving doe not get any better
Is there a easy fix were do I start. Thanks |
Posted: Sat Jun 22, 2024 10:00 pm Post subject: |
I would look at the electrical connections. You may just have a loose connection on the gauge or there may be corrosion where the wire connects to the sender unit.
IT is a long wire so check continuity and be sure you have a good earth.
If the connections check out you may have a faulty gauge.
As a last resort you may need to check the float on the sender unit for a leak.
Southernscouse
Posted: Sun Jun 23, 2024 10:29 am Post subject: Fuel gauge |
| Thanks for the reply gives me somewhere to start |
