Southernscouse
Joined: 30 May 2024 Posts: 26 Location: Havant Hampshire
Posted: Thu Oct 10, 2024 2:03 pm Post subject: Brazeing |
| Is this a feasible option for body work repairs I have a O/A kit but sometimes acetylene is not always available I am thinking just for body not chassis Thanks |
Posted: Fri Oct 11, 2024 1:24 pm Post subject: |
The trouble you will have with using o/a on modern steel bodywork is heat distortion. You really need a mig or tig welder and even then some distortion is likely. If it is non structural then I prefer to just tack or spot weld and fill with a little epoxy rather than have a distorted panel and loads of filler.
0.6mm wire holds less heat than a 0.8mm so is less likely to blow through thin steel.
Incidentally, there is a general rule that the older the car the better the steel.
If aluminium is to be welded; I would say best leave it to an experienced welder. |
Joined: 23 Nov 2007 Posts: 4265 Location: South Cheshire
Posted: Mon Oct 14, 2024 7:19 am Post subject: |
I have brazed body lap joint repair sections as imho the braze seals the join better. I'm not a fan of lap joints but some times needs must.
Professionals tend to use O/A or Tig for butt joints, as the panel can be planished and shaped after welding, Mig leaves a hard bead that is very difficult to shape , and when ground down or if you get a hammer and dolly on it, the weld can crack.
As Ray mentions Mig is useful if the welded joint is low and can be dressed with filler.
Another option when fitting a non structural lap joint repair is to glue it with something like 3M Panel Bonding Adhesive, apart from the obvious advantage that no heat is required, the joint is water tight, massively reducing the chance of corrosion in future years. |
Posted: Mon Oct 14, 2024 9:50 am Post subject: |
I am a fan of Belzona. There are a wide range of products for a variety of uses ...but the downside is the cost.  |
Joined: 14 Oct 2016 Posts: 2131 Location: East Yorkshire
Posted: Mon Oct 14, 2024 10:33 am Post subject: |
A shout-out for good ol' Tigerseal, too...Takes forever to get off one's fingers! _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Mon Oct 14, 2024 10:49 am Post subject: |
| alastairq wrote: | | A shout-out for good ol' Tigerseal, too...Takes forever to get off one's fingers! |
I am very impressed with Tigerseal and have used it for all sorts of jobs.
May I ask everyone to get a roll of self amalgamating tape. If you need to insulate an electrical connection or a bared wire it is unbeatable...it's cheap and goes a very, very long way.
Back to the topic now I think! |
Posted: Tue Oct 15, 2024 9:35 am Post subject: |
I think many modern adhesives are often overlooked by folk restoring old vehicles as they are viewed as a bodge, I'd wager that many of the structural adhesives would offer stronger, longer lasting repairs than some restorers welded efforts!  |
Posted: Wed Oct 16, 2024 4:46 am Post subject: |
| ukdave2002 wrote: | I think many modern adhesives are often overlooked by folk restoring old vehicles as they are viewed as a bodge, I'd wager that many of the structural adhesives would offer stronger, longer lasting repairs than some restorers welded efforts!  |
You could easily be right there, but of course achieving a satisfactory bond will involve the sort of thorough cleaning that isn't always easy on an old car. |
Southernscouse
Posted: Wed Oct 23, 2024 8:58 pm Post subject: Brazeing |
| Thanks for the replies gives me more to think about |
