Bleed nipples
Southernscouse
PostPosted: Tue Mar 25, 2025 7:16 pm    Post subject: Bleed nipples Reply with quote
1954 Austin Devon van can anyone tell me the thread tpi of both front and back brake bleed nipples have put the same question on the accc site thanks
PostPosted: Tue Mar 25, 2025 9:38 pm    Post subject: Re: Bleed nipples Reply with quote
I think they are 3/8" x 24 TPi UNF.
Please don't just take my word for it.
bjacko
PostPosted: Wed Mar 26, 2025 5:54 am    Post subject: Wheel Cylinder Bleed Nipple Reply with quote
The wheel cylinders do not appear in the Lockheed Parts catalogue so I assume must be some other make. 1959 and on do appear.
Classicbrakeandelectric8 in Lincolnshire have a set of wheel cylinders for sale, maybe they can advise you the make and or part number/thread type for the bleeders.
1985 Rover SD1 VDP
PostPosted: Wed Mar 26, 2025 9:14 am    Post subject: Reply with quote
I'd advise checking the actual threads on the cylinders, reason being that pattern parts may well have a different thread to original.
They are almost certainly going to be UNF threads, probably either 1/4 " or 3/8". You may have different brands of cylinders on the same axle, so check each cylinder.
