Machining Pistons
Miken
PostPosted: Wed Sep 10, 2025 4:15 pm    Post subject: Machining Pistons Reply with quote
I thought this might be of interest.
It has nothing to do with old cars. But it easily could have (and it is a Bentley engine!).
I needed to machine some pistons all over on my lathe, but how do you hold them?
All the pistons that Ive seen, cars or motorbikes have a turned register in the base of the skirt which is for locating it during the manufacturing process.
First you need to make an eye bolt.
Then you turn a mandrell to locate the piston on:
PostPosted: Wed Sep 10, 2025 5:59 pm    Post subject: Reply with quote
I agree that is probably the best way.
How about some thin swarf. ? This was my final pass on a hollow distance peice for the bolt mounted Altette horn. Very Happy
PostPosted: Wed Sep 10, 2025 8:23 pm    Post subject: Reply with quote
Strikes me that the set-up shown in the first 2 pics must have some tight "non-clearances" otherwise you would get a lot of chatter on the lathe.
Miken
PostPosted: Wed Sep 10, 2025 10:23 pm    Post subject: Reply with quote
The spigot of the fixture held in the lathe chuck is made a snug fit so each piston runs true.
Each piston and eye-bolt is simply tightened by hand.
Pistons are made from cast iron. It's for a 9 cylinder engine.
Also;
slightly interesting design; W O Bentley designed this engine with hollow con-rods. Oil travels up the centre to lubricate the small ends.
I haven't seen this on an IC engine before.
PostPosted: Thu Sep 11, 2025 12:00 pm    Post subject: Reply with quote
I think hollow con rods were often found in aero engines but not all used them to lubricate the small ends. I understand the system is still found in high performance engines but not necessary in everyday use.
