Rusty
Joined: 10 Feb 2009 Posts: 317 Location: Bunbury, Western Australia
Posted: Thu Sep 25, 2025 10:23 am Post subject: Singer water pump advice needed! |
Another member of my car club has just had the seal in his 1953 SM 1500 OHC engines water pump start leaking "badly" and I went out today and pulled it off for him so he can try and find a replacement. He knows somewhere he "may" find one, but "I" suspect not, so it looks like I will overhaul it for him. Does anyone know of a source of advice I can contact to find out a few things about these pumps? The seal is mounted in the impellor and seals against the housing, and it has two independent "unsealed" ball races in it on the shaft, and also doesn't appear to have any water drain holes in the pump casting in case of seal failure, which is something I don't believe I have ever "not" seen before. The pump has definitely been worked on before and I am wondering if it's been altered in spec in any way.
I have registered on the Singer club website and am just waiting to have my account activated by an administrator so thought I would ask you blokes if you know anyone I can talk to about it.
Thanks,
Graham |
Joined: 16 Oct 2008 Posts: 1206 Location: Upper Swan, Western Australia
Posted: Thu Sep 25, 2025 12:47 pm Post subject: |
Hi Graham,
I think there may be a Singer owner in the VCCC Collie branch. Give Secretary Hamish a bell to check.
Keith _________________ 1926 Chrysler 60 tourer (100 years old! - a genuine antique!)
1950 Austin A40 tourer
1999 BMW Z3
Posted: Thu Sep 25, 2025 2:29 pm Post subject: |
| You may be use/ adapt an off the shelf seal, bearing companies like Simply Bearings, stock a huge range of seals. |
Joined: 14 Oct 2016 Posts: 2281 Location: East Yorkshire
Posted: Thu Sep 25, 2025 6:01 pm Post subject: |
| Quote: | | Simply Bearings, stock a huge range of seals. |
To the sound of flapping flippers?  _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Thu Sep 25, 2025 6:49 pm Post subject: |
| alastairq wrote: | | Quote: | | Simply Bearings, stock a huge range of seals. |
To the sound of flapping flippers?  |
Would those seals be common? |
Rusty
Posted: Fri Sep 26, 2025 1:09 am Post subject: |
G'Day Keith, the owner "is" a member of the VCC and associates a lot with the Donnybrook branch, of which I am a member. He has already been in touch with someone at the parts shed and is going to have a look there tomorrow, but I think the chances of finding what he needs is pretty remote. There is apparently someone working on a car in the "deep South" possibly Albany way that has recently raided the VCCs stock of Singer parts and they aren't sure what's there now so I think he is going up to check it out.
I was reading last night on the Singer club website that a seal that will fit without modification (PS-142) is available from industrial suppliers, so will check that out. It is an unusual pump in as much as it seems to have been designed to discharge any water leaking past the seal "through" the bearings to the outside behind the pumps drive pully, that is something I haven't seen before, as they more normally have a drain from the cavity behind the seal and in front of the bearings to the outside, and pushing coolant through the bearings themselves seems somewhat "odd"! It looks like a pretty easy pump to overhaul as long as the bearings are available and I think they should be a standard size, by the 1950s most of the oddball "imperial" bearings had been metricised! |
Joined: 20 Aug 2008 Posts: 1509 Location: Netherlands
Posted: Fri Sep 26, 2025 11:58 am Post subject: |
Not having a drain hole in the pump is not as rare as it seems. The first waterpump of the Hillman Imp also had no drain. It was followed up pretty soon with a pump which had a drain hole. _________________ a car stops being fun when it becomes an investment |
Rusty
Posted: Sat Sep 27, 2025 4:34 am Post subject: |
| badhuis wrote: | | Not having a drain hole in the pump is not as rare as it seems. The first water pump of the Hillman Imp also had no drain. It was followed up pretty soon with a pump which had a drain hole. |
Maybe it's something "Rootes" engineers liked for some reason! Did Rootes actually "built" the Imp engine under licence, or was it built by Coventry Climax (and I have no idea if they were aligned with anyone else)
Of course the Singer OHC engine was "pre Rootes" so I won't blame them anyway! |
Posted: Sun Sep 28, 2025 10:25 am Post subject: |
The Climax FWMA engine was used in the prototype but Rootes altered it a lot. Despite very similar looking no parts are actually shared.
The water pump is a full Rootes design.... and needed several versions to become finally (somewhat) reliable.  _________________ a car stops being fun when it becomes an investment |
Rusty
Posted: Mon Sep 29, 2025 1:16 am Post subject: |
| badhuis wrote: | The Climax FWMA engine was used in the prototype but Rootes altered it a lot. Despite very similar looking no parts are actually shared.
The water pump is a full Rootes design.... and needed several versions to become finally (somewhat) reliable.  |
Looks like maybe I can blame Rootes !
I haven't heard back from the Singers owner over the success or otherwise of his search on Saturday, but suspect he may need an overhaul, so I will start getting ready. I will need access to a lathe to reface the seal running surface, but I just did a favour for a fellow club member by doing some work on the distributor and starter motor of his Humber Super Snipe, and he has a small lathe, so I think I will put the hard word on him for a "borrow" to reface the pump. I am the little white haired boy at the moment, the Humber is running the best it has since he has owned it, we went on a run yesterday and it went like a champ. It had a defunct vacuum advance diaphragm, but he got a spare car wreck with a serviceable distributor and now has more power, smoother running and better fuel consumption, so he is happy enough I don't think he will mind me borrowing the lathe for a couple of minutes.
Will keep you posted on any outcome! |
Rusty
Posted: Fri Oct 03, 2025 6:19 am Post subject: |
Well, I got the pump "off and apart", The seal and seal surface definitely need attention. I have ordered a "PS-142" or equivalent seal off the local bearing suppliers which should be here in a few days. The bearings (2 of) were stocked locally, which is a bit surprising because they were an old "imperial" size, not the more common metric. I will have to get hold of the bloke with the lathe to face the seating area, and as that is on the housing rather than the impellor it will be a bit more involved than what I am used to. Will still have to locate some "calcium based" water pump grease for it, but I think it should be available, so we will see.
All in all, going as well as could be hoped for. |
Rusty
Posted: Fri Oct 10, 2025 4:43 am Post subject: |
I have just had the bearing company I ordered the seal through tell me their seal supplier can't supply one!
I have found out through other sources that the PS-142 seal will fit, but you want to be careful, because what you really need is apparently a PS-142V, the V denotes a carbon seal face compatible with cast iron running surface, the number without the "V" is a plastic surface and needs the ceramic insert to operate successfully. I have ordered a John Crane type 6A seal I am assured "will" fit by the measurements and also has a carbon face for use on the cast iron surface. It's being a royal pain sorting this out but hopefully "getting there"!
We faced the seal surface of the pump housing yesterday so now all I need is the seal and we are in business. The turning of the housing was easier than I had anticipated and looks like it should work quite well.
I have mostly detailed what I am up to, to try and inform anyone doing what I have been and looking for info "on-line" because there seems to be very little Singer information available and I have so far not found "anyone" familiar with the Singer cars to actualy have a conversation with. |
bjacko
Joined: 28 Oct 2013 Posts: 596 Location: Melbourne Australia
Posted: Fri Oct 10, 2025 7:17 am Post subject: Singers |
There seems to be a fairly active Singer club in Melbourne, but I do not know any of them or anything about the club. They used to put on a good display at the British and European display each year. _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
1985 Rover SD1 VDP |
Rusty
Posted: Fri Oct 10, 2025 11:21 am Post subject: Re: Singers |
| bjacko wrote: | | There seems to be a fairly active Singer club in Melbourne, but I do not know any of them or anything about the club. They used to put on a good display at the British and European display each year. |
Yes, so I believe, but like the Singer club in the US, I registered and then "nothing", it's been about 10 days and no contact back and no access to their forum. It might be something I am doing because I am about "grade 2" in computer literacy!
Dave the "PS 142" seal is quite common and definitely sold for "pool pumps" but in that application they use the replaceable ceramic seat, the PS-142 which is bandied around as being an acceptable direct replacement for the originals will fit straight in, but if what I have been told is right, (and I am only taking a seal specialists advice) the PS-142 with a "hard plastic" seal is only good for the pumps that use the ceramic insert, to discard the ceramic seat and use the cars original water pump housing you would need a carbon type seal that has a capacity to last on a cast iron surface such as the original, that is according to "the man" a PS-142V.
Just putting what I have been told out there for others but please if you see this check it out. I have a PS-142V coming to put in my friends car, but it will be some time before I know if all is well. |
