Posted: Tue Jan 13, 2026 11:32 am Post subject: Unusual coil. |
This 6 volt 3 amp 'Auto Lite' coil (Ebay) is unlike anything I have seen before. Perhaps someone can explain why there are two HT outlets? Could it be for twin distributors?
Joined: 23 Nov 2007 Posts: 4311 Location: South Cheshire
Posted: Tue Jan 13, 2026 1:29 pm Post subject: |
| Probably from a 2 cylinder engine utilising Wasted Spark ignition, eliminates the need for a distributor, possibly from a bike where space is limited. |
Posted: Tue Jan 13, 2026 2:47 pm Post subject: |
| ukdave2002 wrote: | | Probably from a 2 cylinder engine utilising Wasted Spark ignition, eliminates the need for a distributor, possibly from a bike where space is limited. |
Thanks for that explanation, Dave.
Harley Davidson for example. |
Rusty
Joined: 10 Feb 2009 Posts: 299 Location: Bunbury, Western Australia
Posted: Wed Jan 14, 2026 12:24 am Post subject: |
| I have never actually looked, but someone told me years ago that 2CV Citroens fired the plug on both compression and Exhaust, if that is true then they would be the most common type that might use that style of coil! |
norustplease
Posted: Wed Jan 14, 2026 10:09 am Post subject: |
I think that a 2CV is a Boxer, ie it fires both cylinders simultaneously. The coil is double ended, there is no distributor as such, just a set of points at the front of the engine attached to the camshaft. It only fires on compression. _________________ 1953 Citroen Traction
1964 Volvo PV544
1973 VW Beetle 1303L
Boring Suzuki SX Hybrid |
Posted: Wed Jan 14, 2026 11:56 am Post subject: |
| norustplease wrote: | | I think that a 2CV is a Boxer, ie it fires both cylinders simultaneously. The coil is double ended, there is no distributor as such, just a set of points at the front of the engine attached to the camshaft. It only fires on compression. |
Both spark plugs fire simultaneously but not both cylinders. The spark firing on the exhaust stroke is wasted. |
Joined: 14 Oct 2016 Posts: 2185 Location: East Yorkshire
Posted: Wed Jan 14, 2026 12:52 pm Post subject: |
IIRC, the coil is double ended on a duck shoveller _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Wed Jan 14, 2026 3:08 pm Post subject: |
| alastairq wrote: | | IIRC, the coil is double ended on a duck shoveller |
Having led a sheltered life...I know what a shoveller duck looks like...but what is a "duck shoveller", please? |
Posted: Wed Jan 14, 2026 5:49 pm Post subject: |
| Quote: | | Having led a sheltered life...I know what a shoveller duck looks like...but what is a "duck shoveller", please? |
Hah! Deux Chevaux......Dux chevux... _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Wed Jan 14, 2026 9:32 pm Post subject: |
| alastairq wrote: |
Hah! Deux Chevaux......Dux chevux... |
Yes, the coil is double ended. The clever thing, of course, is that there is no distributor; no need.
Such a foolproof design. Like everything about those cars it is designed with reliability at it's heart.
If only they were still being made, the world would at least have some sanity left. |
