Universal electric fans.
PostPosted: Fri Mar 13, 2026 1:43 pm    Post subject: Universal electric fans. Reply with quote
I have been pondering how these work.
A fan blade is designed to work in one direction so I am intrigued by adverts for electric radiator fans that are being sold as "universal" i.e. suck or blow depending on direction of rotation.
Surely, any curved blade fan will work better if it is used as designed?
OK , maybe air flow will be directed dependent on rotation ...but surely far better in one direction than another?
PostPosted: Fri Mar 13, 2026 9:02 pm    Post subject: Reply with quote
I suppose the description is correct, but depending on which side of the radiator the fan is fitted, or which way round?
PostPosted: Fri Mar 13, 2026 10:58 pm    Post subject: Reply with quote
Yes Dave. The fan could be mounted on either side of the rad but I can't see it shifting the same CFM if rotation is reversed.
It is interesting to note that for maximum efficiency the better makes of fan offer either a "push " or a "pull" depending on your requirements.
I expect (and I haven't checked this out) that a "universal" fan will work in both directions. It may sound appealing...however ... the volume of air may flow more in one direction than another; a point that is probably ignored by the sellers.
PostPosted: Sat Mar 14, 2026 3:57 pm    Post subject: Reply with quote
I always understood the meaning of 'universal fan' to be, it can be fitted to anything...rather than having a specific fitment?
