| Do you like or dislike the new dashboard ? |
| Yes I do like the new dashboard |
100% |
[ 7 ] |
| No I do not like the new dashboard |
0% |
[ 0 ] |
| Total Votes : 7 |
Joined: 14 Oct 2016 Posts: 2185 Location: East Yorkshire
Posted: Tue Mar 17, 2026 11:00 am Post subject: |
On the topic of records of entry?
Several scenarios come to mind, so the presence of UW 5990 entering a section on the Bisley event could be from a competitive point of view..?
Or even, an organisational viewpoint?
Entrants into such events could find they have had a change of vehicle, after the entry lists have been printed, for example.
Or, even, an entry submitted , but accepted, too late to be included in the published entry list itself?
Or, if the driver & car were part of the organisational team, and the car was a 'section or course' opener?
On the bigger trials of late [Pre-online entry systems] actually getting an entry could be a bigger challenge than the trial itself....entry opened, completed entry forms posted back, sometimes with recorded delivery if desperate..with entries 'closed sometimes a day or so after being opened, such was their popularity amongst grass roots sporting drivers.
I have experienced posting an entry form back a couple of days after the opening date, to find my self on the 'reserve' list! Anxiously awaiting a full entrant to prematurely drop out...As frequently happened, when poorly machines, or poorly drivers struck....or even, passengers being reluctant to come forwards. _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Tue Mar 17, 2026 12:19 pm Post subject: |
Hi Alastair. The VSCC (who organised the event) have a library of Motoring history. They been very helpful with research but have no definitive answer for why UW 5990 was not recorded. As you have suggested, there are several possibilities.
For what it's worth back in 1950 events such as this were a far more relaxed affair. |
Posted: Tue Mar 17, 2026 1:51 pm Post subject: |
| Quote: | | For what it's worth back in 1950 events such as this were a far more relaxed affair. |
They still are!
But the bigger events [especially] had entry number limits imposed upon them [several hundreds]....by the rules of the governing authorities.
Hence the need to get one's entry 'in the post' more or less as soon as the entry forms plunge through one's letterbox?
Trialling was [& still is] an immensely popular, grass-roots form of motorsport....one which had direct implications for new & used car sales.
[Also it's probably the cheapest form of motorsport, still, in terms of entry fees?] _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sun Mar 22, 2026 8:18 pm Post subject: |
I have been looking to finish the side screens but getting the frames and covers in the best position against the hood is tricky.
Eventually I decided to hold everything in place with masking tape, then, when aligned, I marked with a pen through the bolt hoes where the fixings need to go.
In total there are 62 x 3BA special oval head screws that are designed to slide and lock into the back of the chrome trim strips that finish the edges of the windows.
The screws then pass through the fabric and holes in the frame, where they are attached on the inside of the car.
However, before I can fit the trim, each piece (which is of a different length and with different angles) needs to be mitred. To do this the trim sections will need to be 'dry run' fitted to the frames. For this I will need sufficient 3 BA nuts.
I thought I had enough 3BA nuts for the job ...but then realised that those I have are 2 BA. This has meant ordering a supply. Unable to find 3BA nuts in stainless steel, I have chosen plated ones in an attempt to keep the rust at bay.
To avoid any confusion about which of the corner fillets go where, I have stuck them to the fitting instruction sheet in the positions they will be in when installed into the trim pieces.
Posted: Tue Mar 24, 2026 5:39 pm Post subject: |
So...the original used TC side screen trims are something of a curate's egg; ie. good in parts.
Unfortunately, someone has mitred them incorrectly.
They should obviously look more like this:
Posted: Thu Apr 02, 2026 8:42 pm Post subject: |
After what seems like an age, I have finished making up the side screens. The smaller, rear screens are seen here fitted to the body tub. Note the rectangular chrome plate attached by four raised c/s wood screws is let into the hidem banding. (I needed to cut out a small section of banding so that the plate would sit flat on the panel) The side screen front leg has a forked end that slots onto a stud protruding from the plate held firm by a wing nut.
Unfortunately, the legs of the front screens are not long enough to reach their securing plates. I had forgotten about this and it means they will need a 3cm piece welded in. |
JC T ONE
Posted: Sat Apr 04, 2026 5:18 am Post subject: Interior |
Your car has the same colour as Mr Brandt & Jaguar House of Copenhagen ordered for the Wood & Pickett Margrave Elite, in 1973.
Love your matching seatbelts
Will you do the 3cm extension welds your self ? _________________ http://www.eurods.eu/wp/index.html |
Posted: Sat Apr 04, 2026 11:52 am Post subject: Re: Interior |
| JC T ONE wrote: | Your car has the same colour as Mr Brandt & Jaguar House of Copenhagen ordered for the Wood & Pickett Margrave Elite, in 1973.
Will you do the 3cm extension welds your self ? |
Thanks for following. The colour is called "Mountbatten Sand" and is a top of the range natural leather by UK Leather. It took four hides to complete the interior trim - which apart from the new seat, I did myself. Not blowing my own trumpet, but I think the results speak for themselves and are a big improvement on the original leather/vinyl mix.
I am glad you like the seat belts. Belts were, of course, not originally fitted... and are for many "purists" a step too far...but as they can be tucked away behind the seat I am happy that they do not detract from the aesthetic.
With regard to the front side screen frames; I was not happy that the "leg" was not long enough to properly locate onto the stud. Theoretically, they should fit... but like everything to do with this car they will need "tweaking". Even with the chrome plate mounted at the top of the door card, the hook would not fully reach. Therefore, I shall be adding a 3cm piece to each front side screen 'leg'. This should allow me to mount the plate flat on the panel below the hidem banding (save cutting it) and be secured fully with the wing nut.
As it happens, I do all my own welding. Unfortunately, I will need to buy a new argon/CO2 disposable gas bottle for the MIG welder, as the last one I bought just 8 weeks ago has leaked out all its contents.! |
Posted: Sat Apr 04, 2026 2:00 pm Post subject: |
Hobbyweld?? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sat Apr 04, 2026 3:00 pm Post subject: |
| alastairq wrote: | | Hobbyweld?? |
The initial cost of 70 quid has always put me off...but this is not the first time a disposable bottle has leaked out so maybe Hobyweld is worth another look? |
Posted: Sat Apr 04, 2026 3:09 pm Post subject: |
It is a one-off payment...you only pay for the gas subsequently. It's a big bottle as well...proper stuff.
Provide your own pressure gauges etc though.
Cheaper than Energas or subscriptions...
Probably the cheapest way to go if only welding sporadically....In other words, the gas is always there when you need it. _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sat Apr 04, 2026 6:36 pm Post subject: |
I am going to try my hand with brazing again. Last time I couldn't get enough heat into it. I now have a better blow torch and more suitable gas. It is something I have always wanted to do but never achieved.
Just one of those things I wish my Dad had taught me.  |
Posted: Thu Apr 09, 2026 3:09 pm Post subject: |
So...The new fan is fitted and works O.K.
Before fitting the rad shell I re-painted the top of the radiator where the black paint had become scratched. The bonnet is back on (with bit of a struggle) and the radiator shell is also back on (again a struggle) and the headlight brackets are screwed back on, although one of the threads has stripped with no effort.
I re-painted the headlamp retaining nuts and secured them to their supports. The wires were inserted from underneath and connected to the reflectors; making sure the earth wires were tight.
Unfortunately, the lights don't work properly.
Either one of the bulbs has a poor holder connection ...or it is a faulty bulb. I have had problems with these bulbs before.  |
bjacko
Joined: 28 Oct 2013 Posts: 557 Location: Melbourne Australia
Posted: Fri Apr 10, 2026 7:39 am Post subject: Bolts |
Modern bolts, screws and nails seem to be made of poor quality steel these days. Threads strip too easily heads break off and nails bend like rubber. _________________ 1938 Morris 8 Ser II Coupe Utility (Pickup)
1985 Rover SD1 VDP |
JC T ONE
Posted: Sat Apr 11, 2026 12:50 am Post subject: |
| Ray White wrote: |
Do you have a mini tester with Ohm funktion ?
It will tell you where the poor connection(s) are.
Good luck. _________________ http://www.eurods.eu/wp/index.html |
