momentary starter switch.
PostPosted: Fri Apr 10, 2026 11:32 pm    Post subject: momentary starter switch. Reply with quote
I have a pull cable attached to a starter solenoid which in turn is connected by heavy cables to the battery and the starter.
The cable pull is O.K. but (I have painful hands so) would much prefer to just push a button on the dash.
I intend using a relay to save having high current going through the push button switch but because the cables to the solenoid are big, I am looking for help with the smaller wiring.
The car is positive earth and fitted with a modern high torque starter motor. In addition to the cables, there are some small wires to the starter motor ...but I am out of my depth with how to add the wiring for a momentary switch.
Any help would be much appreciated. Thank you.
PostPosted: Sat Apr 11, 2026 7:00 am    Post subject: Reply with quote
Hi Ray
You will require a solenoid like this:
Simply swap the battery & starter motor cables from the pull starter, to the new solenoid.
To activate the solenoid use a momentary switch such as this:
There will be 2 spade terminals on the solenoid to activate the solenoid coil, on some solenoids one side of the coil may be attached to the solenoid frame, check for this with a meter, if one side of the solenoid coil does go to the case this terminal will need to be attached to the chassis (ground) otherwise it doesn't matter. The other terminal goes to one side of the momentary switch, the other side of the switch will go to battery negative (as your car is positive earth.
PostPosted: Sat Apr 11, 2026 8:36 am    Post subject: Reply with quote
ukdave2002 wrote:
Hi Ray
THat's very helpful Dave, thank you. I have got one of those solenoids somewhere. It is now just a case of finding a suitable place to mount it.
PostPosted: Tue Apr 14, 2026 6:19 pm    Post subject: Reply with quote
Please could I have this photo explained?
This is my high torque starter motor. It is supplied with 12 battery power from a cable pull type solenoid.
What I don't understand is the purpose of the white wire that is connected to the high amperage terminal and goes into the starter. Does it go to a solenoid built into the starter?
Is this a 'trigger' wire? and could I use it with a link to a momentary switch?
PostPosted: Tue Apr 14, 2026 6:52 pm    Post subject: Reply with quote
Yes I think it could be.
If it?s the same starter that?s in this article
https://abingdonspares.com/blogs/tech-tips/tips-on-installing-high-torque-starters-mg-t-types
PostPosted: Tue Apr 14, 2026 8:24 pm    Post subject: Reply with quote
Yes it is. Thank you for that. I can now simply take the white wire off the motor and Join it to a wire going to a momentary push button. The heavy wire can now go direct to the battery - terminal avoiding the original pull cable solenoid.
It is also important to me to keep the original arrangement available so it could be easily reinstated if desired.
PostPosted: Mon Apr 20, 2026 3:11 pm    Post subject: Reply with quote
One last question...
The bulkhead mounted solenoid has a useful plunger button which allows you to operate the starter from the engine bay.
Is there a way to keep it connected to the cable pull while also having the trigger wire to a momentary switch on the dash.
In other words either a pull knob (as original) or push button (to save my painful fingers).?
PostPosted: Mon Apr 20, 2026 4:15 pm    Post subject: Reply with quote
Double the wiring ....?
PostPosted: Mon Apr 20, 2026 9:32 pm    Post subject: Reply with quote
I would need to know for sure what wires to connect or join. I just don't have the confidence...
PostPosted: Tue Apr 21, 2026 9:05 am    Post subject: Reply with quote
Is the internal starter Solenoid required to engage the starter , or does the motor rely on traditional inertia to engage? if the later its really simple.
PostPosted: Tue Apr 21, 2026 9:09 am    Post subject: Reply with quote
I'm over thinking it!
Simply wire the new momentary switch in parallel with the original starter switch, so that either can be used.
PostPosted: Tue Apr 21, 2026 1:17 pm    Post subject: Reply with quote
Does that just mean taking the small white "jumper" wire off the starter terminal and joining it to the momentary switch wire?
PostPosted: Tue Apr 21, 2026 2:32 pm    Post subject: Reply with quote
The wires on the starter should be as per the example shown for the momentary switch as above.
The wires to the momentary switch can also each have a wire joined to them, and run to the ''pull'' starter switch.
Both types of switch will be ''make/break'' switches...both complete a circuit to the starter motor [relay]. Doesn't matter which switch you use...
PostPosted: Tue Apr 21, 2026 3:23 pm    Post subject: Reply with quote
I can copy the wiring as shown.
What I am now confused about is the need for a wire from the momentary switch to the "starter pull switch" which is basically a separate solenoid on the bulkhead.
Confused
Presently the "pull" cable is attached to a pin at the back of the bulkhead mounted solenoid. To one terminal of this solenoid is attached a heavy cable from the battery and from the adjacent terminal is another heavy wire that goes to the starter. Where, exactly, would I need to fit a thin wire from the momentary switch ?
PostPosted: Tue Apr 21, 2026 3:30 pm    Post subject: Reply with quote
Yes, and the other side of the momentary switch will go to battery negative (as you have positive earth) which can be done by connecting it to the battery side of the existing starter switch, at the same time disconnect the heavy cable from the other side of the original starter switch (the cable that goes to the starter motor) and attach this to the battery side of the original starter switch. (the starter motor wont turn over because you have disconnected the white internal solenoid cable)
Finally attach a cable from the original starter (the side that used to go to the starter motor) to the side of the momentary switch that goes to the white solenoid wire.
You could of course connect the heavy battery cable directly to the starter motor, I'm assuming the existing one wont be long enough, so using the original starter switch as a terminal is probably simpler.
