MG TC
Goto page Previous  1, 2, 3 ... 97, 98, 99, 100  Next
100%
 100%  [ 7 ]
0%
 0%  [ 0 ]
Total Votes : 7
JC T ONE
PostPosted: Sat Apr 11, 2026 12:54 am    Post subject: Re: Bolts Reply with quote
bjacko wrote:
Modern bolts, screws and nails seem to be made of poor quality steel these days. Threads strip too easily heads break off and nails bend like rubber.
Speaking of rubber = thats another material, they cant reproduce correctly.
Grommets break - seals for doors & lids are too hard etc etc
PostPosted: Sun Apr 12, 2026 12:37 pm    Post subject: Reply with quote
I may not be much good at electrics but I think I can get away with a bit of welding. The top weld has been ground back ...and there is one anxiously awaiting it's turn !
This is the extended leg of the front side screen frame being mig welded.
Laughing
PostPosted: Thu Apr 16, 2026 1:12 pm    Post subject: Reply with quote
The problem of the engine running far too rich (even when warm) persists. The single carb attached to the supercharger is an SU H6. I was advised that this would give better performance than the H4 as found on other similar installations.
The carb was supposed to have been new when supplied with the supercharger ...but I am not so sure now. Burlen's instructions for checking the petrol level in the float chamber say that with the lid inverted, a 7/16" bar should just pass between the float arm while resting on the sides ..but there is considerably more clearance than that! The level must be too low ...so I have adjusted the arm to the desired position as suggested.
I have a suspicion that this carb has been tampered with.! Surprised
Following lengthy telephone conversations with Burlen I have chosen to purchase a new needle. The present one is a D1. After some research, I have been advised to fit a KK needle. This has the benefit of a leaner mixture up to 3750 RPM and a richer mix thereafter. The important thing to watch with a supercharger is not to run lean at speed. This needle should prevent that.
The current spring is an unknown quantity as there is no colour coding on it... but if I still think the mixture is too rich, I will be changing to a blue (leaner) spring.
This is a step by step; trial and error business so we will see how things turn out. I await the postman!
JC T ONE
PostPosted: Fri Apr 17, 2026 2:26 am    Post subject: Reply with quote
Nice welding job Cool
Hope you get the mixture issue fixed .
PostPosted: Fri Apr 17, 2026 9:37 am    Post subject: Reply with quote
Maybe worth getting the SU tuning book? [If only to read at bedtime?]
The spring can be identified by the usual methods of measurement.
What grade of oil are you using in the dashpot?
[Is the set-up a 'suck through,' or a 'blow through' system??]
PostPosted: Fri Apr 17, 2026 12:14 pm    Post subject: Reply with quote
Hi Alastair. The system is with an H6 SU carb attached to a supercharger ,,,so I guess the air is sucked through the carb before being blown into the engine.
The H6 carb would normally have a 4.5 Oz spring (Burlen red) but as there is no colour code I thought I would check it out. With a 2.6" cardboard distance piece (as recommended) in the spring mounted on the kitchen scales, It measured an incredible 12oz. This is three times what I was expecting and in my opinion would be a contributing factor in rich running.
The blue spring that I am getting may be too lean with the new KK needle; I will have to fit it and see. Maybe a red one would be sufficient.
I am using 20/50 engine oil in the dashpot. If it starts to run lean I may use a heavier oil.
More than one way to achieve the ideal mixture, I am sure.
I have an old copy of the SU manual some where but can't seem to find it at the moment; no worries ... it is all "on line" . Rolling Eyes
PostPosted: Fri Apr 17, 2026 2:36 pm    Post subject: Reply with quote
The oil thickness [or, thin-ness]..mainly affects the rate at which the piston rises.
As an experiment, drain the oil out and try some ATF instead? This might allow the piston to rise more quickly for a given vacuum?
Or, find a drop of SAE 20 oil?
PostPosted: Fri Apr 17, 2026 4:51 pm    Post subject: Reply with quote
I will try anything. Thanks.
The spring in there, however, is waaaaaay too strong.
I have a spare 4.5oz. spring that I shall try with the existing needle and see what happens.
Of course, even if I resolve the rich ticker, I shall only know how the various needles/springs are really performing when I can get the car on a rolling road.
I tried Peter Burgess in Alfreton (who comes highly recommended for tuning older cars) but unfortunately he will not be taking on any more rolling road jobs until June.
PostPosted: Sun Apr 19, 2026 7:01 pm    Post subject: Reply with quote
Over the last couple of days I have been experimenting with different combinations of needles and springs but without much success.
It seems the mixture is either too weak or too rich. . The new KK needle that Burlen sent is too weak.
Strangely, the best running mix is with the original R1 needle and a 4 1/2oz. spring... but where I am confused is that the engine seems to "hunt" as if it were running rich ...but then backfires through the carb/supercharger as though it is running lean.
At one point I was convinced that the engine was misfiring but a few checks revealed that the plugs were all sparking and there is 105 PSI on all the cylinders.
At the moment I am left scratching my head; especially as Steve Baker (MG specialist) set the electronic ignition timing. Confused
PostPosted: Sun Apr 19, 2026 7:21 pm    Post subject: Reply with quote
If only we could have a device that measures the oxygen content of the exhaust, the amount of of airflow, together with the temperature and position of the throttle, analysis all this and then, then trims the correct amount of fuel to be injected!,😜😜
On a serious note, Electronic ignition is timed in exactly the same way as points, the only service difference is that the plug gaps can be opened up a tad to take advantage of the improved spark.
PostPosted: Sun Apr 19, 2026 10:54 pm    Post subject: Reply with quote
My electronic distributor has a dozen different settings. It depends on how many times the red light in the distributor flashes.
That aside, I think the H6 is probably unsuitable for such a small engine; with or without a supercharger. It has been suggested that an H4 would have been better but the supercharger came with the H6 fitted.
JC T ONE
PostPosted: Mon Apr 20, 2026 3:54 am    Post subject: Reply with quote
If you only have one HS6 you should be able to adjust it, so it give the right amount.
Yes rolling road, with testing equipment is good.
PostPosted: Mon Apr 20, 2026 8:18 am    Post subject: Reply with quote
Ahh, lots of variables! I think either you find a TC owner whose car has the same (proven good) set up and copy it, or as JC T ONE suggests, its a day on the rolling road, where they can play around with the set up to find the optimum.
PostPosted: Mon Apr 20, 2026 9:03 am    Post subject: Reply with quote
As I said, Peter Burgess (Alfreton) is the "go to" MG guy in this area with a rolling road and he will not be taking any more bookings until June.
Of course, I can't get to anywhere until I have the car running at least half decently and I don't have a trailer. (The guy who used to lend me his trailer is now in a nursing home.)
Again, I don't know anyone who has an H6 SU. The correct carb, I believe, should be an H4 but which might give better throttle response...but we are where we are.
Perhaps I should see if an H4 with a 4 hole supercharger fitting is even available.
(That's another grand up my shirt!)
PostPosted: Mon Apr 20, 2026 9:48 am    Post subject: Reply with quote
IF...you can 'borrow' a trailer...or know of a trustworthy vehicle transporter...then you might do well to get in touch with Bogg Brothers at East Lutton, near Malton[or Driffield, or Bridlington....it's in the 'middle of nowhere!!].
Their dad, David Bogg, is a true magician with his rolling road, Sun tuner, long thin screwdriver, and the ability to fettle an SU needle 'by eye!'
Older cars are his forte, but he's equally happy with an ECU.
[Mind, it's a few years now since I popped in, so I'm not sure of his health situation, as such]..
It would be a 200 mile round trip, but not going anywhere near any sort of urban or metropolitan area.....all countryside...!!
Whilst there will be 'nearer' rolling roads, not many in the country will be a match for David Bogg....and his prices were very reasonable indeed..David, who must be now in his 80's, did the job for 'fun'....
https://www.boggbros.com/
Page 98 of 100
