Joined: 20 Aug 2008 Posts: 1504 Location: Netherlands
Posted: Thu Jul 30, 2026 8:15 pm Post subject: temperature switch |
Like many of us I am not that good when it comes to electrics.
I fitted a new temp sensor which should switch an electric fan. It needs two wires.
On the sensor there is no difference between the spades, no markings.
Am I correct in thinking that when a certain temperature, or higher, has reached the sensor, it will bridge the two spades? So it does not matter how the spades are connected?
One always having 12v, the other one to the fan relay switching it on?
Thanks. _________________ a car stops being fun when it becomes an investment |
Joined: 25 May 2011 Posts: 2840 Location: South Cheshire
Posted: Fri Jul 31, 2026 7:53 am Post subject: |
That's how I would see it, yes. Presumably the switch is rated for a certain temperature, maybe the stampings on the side confirm that temperature. _________________ 1976 Vauxhall HP Firenza, 1976 Vauxhall Sportshatch (x2), 1986 Audi coupe quattro, 2000 Audi TT |
