bob2
Posted: Wed Nov 04, 2026 12:12 pm Post subject: |
Hi Jens, how's life?
Do you still have the WP turbo? |
JC T ONE
Posted: Fri Nov 06, 2026 8:53 am Post subject: |
| Ray White wrote: |
Even my car doesn't have a radio.
My dayli drive dont have radio. I prefer silence.
My Father did love accessories, and my 61 do have a 8 track, but I rarely use it.
Jens Christian _________________ http://www.showcars.dk/ |
JC T ONE
Posted: Fri Nov 06, 2026 8:59 am Post subject: |
| bob2 wrote: |
Hello Malta
Lots have happened - posted a little bit on page 15 & 16 .
Lost many friends, and family.
Keep to myself mostly, and spend time in the workshop, which I nearly lost to a huge fire in December 2025.
Yes its in the garage, been there since 2017.
bob2
Posted: Mon Nov 09, 2026 10:51 am Post subject: |
Sorry to hear of your losses mate.
I still have the minis but sold on the hunter probably around 2020 I think as I had bought another daily a year previously and needed to cull the fleet as I still kept the older daily. That said a year after I wnet out and bought another car, a 1972 MGB roadster.
So I am back to 6 cars!
Presently doing an engine swap on one of the minis as I built up a little 1293cc screamer. |
JC T ONE
Posted: Tue Nov 10, 2026 11:20 am Post subject: |
| bob2 wrote: | Sorry to hear of your losses mate.
Ohh - so you now have a MGB, thats cool
What type/colour = rubber bumper or chrome ? manual / overdrive ?
Not cheap to built a engine these days I guess, what carb & cam ?
bob2
Posted: Wed Nov 11, 2026 11:29 am Post subject: |
The mgb is tartan red with black interior, being a 72, it is a series 2 with rostyle wheels, chrome bumpers and with overdrive as well.
Building the engine was anything but cheap! |
bob2
Posted: Wed Nov 11, 2026 11:35 am Post subject: |
Its got a ported and polished head with big valves, cam is a 286 Kent, with straight cut gears and drop gears and an hif44 carb.
Would have preferred a weber but it will be already quite loud with the sc gears and the rc40! |
Posted: Wed Nov 11, 2026 1:15 pm Post subject: |
| bob2 wrote: | Its got a ported and polished head with big valves, cam is a 286 Kent, with straight cut gears and drop gears and an hif44 carb.
Sorry for interrupting but please can you explain where you fitted the drop gears (otherwise known as transfer gears) in your MGB.
I only know about these in classic Mini/1100 where the engine is directly over the gearbox. |
bob2
Posted: Thu Nov 12, 2026 8:05 am Post subject: |
A couple of previous posts I mentioned doing an engine swap on a mini so you are completely right.
My fault for not claryfing it again as it sounded like the engine is for the MGB in the other post. |
Posted: Thu Nov 12, 2026 12:39 pm Post subject: |
| bob2 wrote: | Presently doing an engine swap on one of the minis as I built up a little 1293cc screamer.
Thank you for clarifying. From memory, worn idler gear bearings was a common fault with minis. We must have done dozens of them. |
JC T ONE
Posted: Sat Nov 14, 2026 5:59 am Post subject: Reply to Mini & MG stuff |
| bob2 wrote: |
Thats nice my Father had stopped driving MG by 1972.
Last British car he had was the 1978 Special, that I have in my garage.
Yes engine stuff is expensive now
JC T ONE
Posted: Sat Nov 14, 2026 6:05 am Post subject: Reply to Ray |
| Ray White wrote: |
Yes that setup had to deal with a lot of torque
JC T ONE
Posted: Mon Nov 16, 2026 6:23 am Post subject: Extreme luck |
Hi all
Here is a few pictures, of a very rare item, I never imagined I would/could find = an original front rubber floor mat for the old 122.
As found =
Ready to go in =
Rear one is not so hard to find, the guy I bought this from, had two.
Cleaning =
Had to be carefull with this one, as the section with the squares, has gone hard due to age, so very brittle.
Also fitted was a original bulkhead felt insulation, in correct Grey.
This was a huge job, as dash + everything else has to come out, in order for the insulation to go in/over = choker cables - speedo cable - steering columm - heater box & valve - temp gauge pipe - pedals - etc etc
Heater was also restored, thanks to E.A.T = Erling for the good job.
Fitting seats 5,30 sunday morning, and the weldnut inside the floor had fallen of so my fire blanket now has a hole =
All the work was totally worth it = it transformed the car completely, its so nice to drive now, and we made it to the car show in Sweden, but 2 hours late.
bob2
Posted: Mon Nov 16, 2026 10:47 am Post subject: |
| Good find Jens, many fiats had similar carpets in the 60s as well and all used to split and fall to pieces in the hot summers we have in Malta. It is almost impossible to find any over here. |
JC T ONE
Posted: Mon Nov 16, 2026 8:23 pm Post subject: Added new pictures to previous post |
| bob2 wrote: | | Good find Jens, many fiats had similar carpets in the 60s as well and all used to split and fall to pieces in the hot summers we have in Malta. It is almost impossible to find any over here. |
Thanks these rubber mats are not very good, if they dont get some care.
I soaked this one with silicone, after I cleaned it.
Used 8 cans on it.
PS I added 3 more pictures to my previous post.
