New Spraygun
Uncle Joe
PostPosted: Mon Mar 03, 2008 3:10 pm    Post subject: New Spraygun Reply with quote
I have decided that it is time to pension off my old spray gun, and get a nice new one. I already have a thought as to which one to buy, but thought that I would see what you others use or recommend.
Well, lets have your ideas!
Job-Rated
PostPosted: Mon Mar 03, 2008 4:54 pm    Post subject: Reply with quote
Devilbiss have a good reputation.
Uncle Joe
PostPosted: Mon Mar 03, 2008 5:08 pm    Post subject: Reply with quote
Its a Devilbiss that I am replacing! I have been pleased with it (over the last 30-odd years!) but it does use a lot of air!
Any more suggestions?
PostPosted: Mon Mar 03, 2008 5:56 pm    Post subject: Reply with quote
I bought a relatively cheap gravity fed gun from machine mart, after some consultation on this forum and painted a Morris (you can see the results on this forum) with it last year .
link to the gun http://www.machinemart.co.uk/shop/product/details/pgf18-gravity-fed-pro-spray-gun
It’s a unit made in China, probably wouldn’t last like a Devilbiss, however it will only get used a coupe of times a year and I’m not a good enough painter to appreciate or use some of the better qualities that a Devilbiss gun would offer.
It was a change for me moving to a gravity fed gun, but didn’t take long to get used to and was easy to use and set up. The biggest draw back was not being able to put it down Confused , so I made a simple stand.
Uncle Joe
PostPosted: Mon Mar 03, 2008 6:10 pm    Post subject: Reply with quote
UK, thanks for reminding me about the chinese guns! I now remeber reading about one that was cheap, but fully capable of matching top quality guns, such as SATA...Now then, who made that?
Must have a look for the old topic..... Shocked
bob2
PostPosted: Tue Mar 04, 2008 10:15 am    Post subject: Reply with quote
does the gravity fed one like the one UKdave posted need less air?
Uncle Joe
PostPosted: Tue Mar 04, 2008 10:58 am    Post subject: Reply with quote
I just had a quick look on Iwatas home page to answer this. Their gravity feed W400 uses 9.9 to 12.7 cfm, depending on model.
Their suction feed uses 11.7 to 12.7 cfm. so i suppose the correct answer is it depends on the model. Very Happy
bob2
PostPosted: Wed Mar 05, 2008 11:22 am    Post subject: Reply with quote
which one would be best for a beginner?
I am spraying only small things like wheels, petrol tank, top covers and so on.
Will have to buy a compreesor also but do not want a big one, what size would be best?
Uncle Joe
PostPosted: Wed Mar 05, 2008 3:36 pm    Post subject: Reply with quote
Bob2, these are difficult questions to answer.
As far as a spray gun goes, if you dont plan on doing much spraying, then go for one of the chinese guns, as UK suggests. Some of them are beginning to get a good reputation for quality. If you are planning to do a lot, then look for a better quality gun.
For compressors, a lot depends on what electricity supply you have, single or three phase, as well as if you are going to use it for anything else in the future. I use one of two. A 3 phase 650l/m (23,1cfm) at 6 bar in the workshop for most things, spraying/cutting/grinding and then a small single phase 98l/m which will only just cope with my sewing machines, and definately not a spray gun....
PostPosted: Wed Mar 05, 2008 6:46 pm    Post subject: Reply with quote
If you are only doing smallish items, I wonder whether the ones model makers use would do.
Some of the model aircraft wings could have as much area as a fuel tank.
Uncle Joe
PostPosted: Thu Mar 06, 2008 8:58 am    Post subject: Reply with quote
If you are referring to airbrushes, then they arent really suitable for items such as wheels. As far as sprayguns go, then look at the following chart from Iwata. Air consumtion really depends on air cap size.
bob2
PostPosted: Thu Mar 06, 2008 9:50 am    Post subject: Reply with quote
To say the truth I dont know what I might be doing in the future !!
However I do not have 3 phase only single phase!!
Which compressor would be best then?
Sometimes I also like to work with wood and was thinking of spraying them since till now I have always brushed the varnish on, so what I buy will also be used for this purpose.
Uncle Joe
PostPosted: Thu Mar 06, 2008 11:24 am    Post subject: Reply with quote
I'd really like to read some opinions from others on this, but my advice would be to get the compressor with the most capacity and largest air tank you can afford that will work on your electricity supply.
For spray guns, check out the following link. Theres a lot of good information on the site.
http://www.spraygunworld.com/
PostPosted: Thu Mar 06, 2008 11:33 am    Post subject: Reply with quote
well I'm no expert, but I'd agree on this point - buy the best you can afford, sooner or later you'll need the extra capacity of a large compressor, especially if you keep buying and working on old British cars Wink
Uncle Joe
PostPosted: Thu Mar 06, 2008 3:45 pm    Post subject: Reply with quote
One thing about spray guns is the fact that you must know what kind of paint is going to be used, 2K or Water Based. At least one major paint manufacturer is recommending that only HVLP guns be used with water based paints. Whether we like it or not, WBP's are going to be the future, so its a bit pointless to buy a gun that cant be used with them.
