Wanted White wall trims for 13" tyres
bob2
PostPosted: Mon Mar 10, 2008 12:24 pm    Post subject: Wanted White wall trims for 13" tyres Reply with quote
Does anybody know of a company that might sell white wall trims for 13" tyres?
I want the narrow ones not the wide ones normally fitted to 50s cars!!
They are sometimes called narrow white walls or also white band!!
It does not matter where the company is located as I'll have to ship them over all the same.
Uncle Joe
PostPosted: Mon Mar 10, 2008 12:40 pm    Post subject: Reply with quote
I can probably get hold of some narrow whitewall tyres for you, will that help?
bob2
PostPosted: Mon Mar 10, 2008 1:50 pm    Post subject: Reply with quote
but tyres will be quite expensive won't they and with shipping will really be much more expensive!!
How much do you think they'd cost though? Confused
SloResto
PostPosted: Mon Mar 10, 2008 2:00 pm    Post subject: Reply with quote
A few years back I saw some Pirellis 14 inch with a thin white wall about 15mm wide. I was interested in finding a set for my roadster which originally had a really nice set of Semperit cross plys with a nice raised wall bearing a thinnish white wall.
I think the Pirellis may have been 600s - I know they were imported from Indonesia so i suspect they may have even been a low end product. I didn't end up getting them as decided to finish mechanicals first and the rest as they say...
Uncle Joe
PostPosted: Mon Mar 10, 2008 2:33 pm    Post subject: Reply with quote
Bob2, let me know the exact sizes, and I will check availability, price and let you know. if I can, I'll get freight costs also.
bob2
PostPosted: Mon Mar 10, 2008 4:13 pm    Post subject: Reply with quote
Hi Sloresto, 14inch are quite common even over here in Malta, 13s are not!!
Ok UJ the diameter is 13 inch, I'll see the width and tyre profile later on this evening cause the car is in a lock up near my mum's house and not in my garage at home.
I think if they are not that much expensive I would buy 8 for sure cause my cousins needs a set as well for his car, probably will be the same sizes!!
PostPosted: Mon Mar 10, 2008 4:23 pm    Post subject: Reply with quote
You could try North Hants Tyres
They seen to have a large stock of whitewalls in their brochure
ROVER
One of Britain's Fine Cars
ianm
PostPosted: Tue Mar 11, 2008 1:21 am    Post subject: Reply with quote
G'day Bob2 are you after a white wall tyre or the whit ewalls you can fit or remove , they fit between the rim and the tyre bead ?
Ian Smile
bob2
PostPosted: Tue Mar 11, 2008 9:42 am    Post subject: Reply with quote
Well depends which option is cheapest!!
Actually I was after the trim that fits between the rim and tyre but I do not want the thick ones but the narrow white bands!!
A supplier over here in Malta told me that he used to stock these sort of white band trims.
They would fit just like the wider white walls but instead of being all white where black at both ends and had a white band in the middle between 1 inch to 2 inches.
PostPosted: Tue Mar 11, 2008 9:56 am    Post subject: Reply with quote
I have a mate with a P5b who had the white trims fitted to his car.
They cut into the side walls, and he was told to use a special grease to prevent this happening.
The grease spun off when he drove and went over the paintwork.
The walls of the tyres got so bad that he had to buy new tyres and the tread was like new.
Be careful if going down this route
ROVER
Uncle Joe
PostPosted: Tue Mar 11, 2008 10:30 am    Post subject: Reply with quote
I have a vague memory that someone else on the forum (PACresta?) has used this kind of trim. Maybe they would have some input? Possibly via a pm if they havent seen the thread.
bob2
PostPosted: Tue Mar 11, 2008 11:04 am    Post subject: Reply with quote
Yes I remember PACresta using such items on his car!!
Thanks uj
bob2
PostPosted: Wed Mar 12, 2008 9:59 am    Post subject: Reply with quote
Hi UJ went to the lock up yesterday but was already dark and since I do not have electricty there could not see anything thats written on the tire wall so still no idea what size I need!!! Sad
Uncle Joe
PostPosted: Fri Mar 14, 2008 5:12 pm    Post subject: Reply with quote
Bob, just let me know when you get the sizes.
