100E torque settings
Craig
PostPosted: Tue Mar 25, 2008 7:30 pm    Post subject: 100E torque settings Reply with quote
Hi, Can anyone tell me the torque settings for the Ford 100E sidevalve main bearings and big ends? I guess they would be the same as the earlier 8 and 10hp engines?
Also, is there anything other than the head which will need to be torqued up? Oil pump maybe?
Was going to have a guess but i thought i'd ask first.
PostPosted: Tue Mar 25, 2008 8:23 pm    Post subject: Re: 100E torque settings Reply with quote
the bearings are different I think in the E93A engines, so don't automatically use the figures for the older engine - just in case. I don't have a 100E manual to hand unfortunately!
PostPosted: Wed Mar 26, 2008 1:06 pm    Post subject: Reply with quote
A guide from a workshop practice book of the era;
Con rods 35-40, Main bearings 45-65
If using high tensile bolts;
Con rods 60-65, Main bearings 80-100 all lb/ft.
Craig
PostPosted: Wed Mar 26, 2008 4:53 pm    Post subject: Reply with quote
Top man ukDave! I knew the main bearings were higher than the big ends but not by how much. Thanks.
