paint removel
Rustynail
PostPosted: Fri Jul 18, 2008 1:59 pm    Post subject: paint removel Reply with quote
Hello
What is the best way to remove the paint off my wolseley 680 ive been using a scraper and its been coming off pretty easy what about paint stripper in a tin any ideas it has brown primer then grey primer then top coat which is blue
Thanks Rustynail
Uncle Joe
PostPosted: Fri Jul 18, 2008 2:37 pm    Post subject: Reply with quote
I normally (there are exceptions) use a DA sander and either 80 or sometimes 40 grit. some friends though get them media blasted with walnut shells, though this is a pro job...
The trouble with paint stripper is that it has to be neutralised afterwards, and sometimes that is not easy.
PostPosted: Fri Jul 18, 2008 4:44 pm    Post subject: Reply with quote
Get some discs for the grinder, I think they are knotted nylon, but make sure they are designed for removing paint (I don't want to be blamed for you getting the wrong discs!).
I use them and they look like a knot of black plastic, frosts sell them and say it takes X number of them to strip there Impala. They work well, strip paint and filler, but not sound metal.
Uncle Joe
PostPosted: Fri Jul 18, 2008 5:06 pm    Post subject: Reply with quote
I think that the discs you mention are the ones made by Eastwood in the US. They certainly look similar, and I know that Frost sell a lot of their stuff. Ask yourself a question. If these discs are so good, why do you never see or hear of a TOP LEVEL pro bodyman using them?
peppiB
PostPosted: Fri Jul 18, 2008 5:08 pm    Post subject: Reply with quote
I use something similar to the knotted nylon - only they go in the drill. They are sheets of the nylon laid together to make a cylinder and remove paint and rust but not metal. I buy mine at car shows or autojumbles - about £1 a time. Haven't managed to destroy one as yet so they have a good lifespan.
Uncle Joe
PostPosted: Fri Jul 18, 2008 5:13 pm    Post subject: Reply with quote
From what I just read, these were originally available for an electric drill, and have been developed for use with grinders.
Thers an old adage that applies to these items...better the devil you know than the devil you dont...
Rustynail
PostPosted: Sat Jul 19, 2008 12:24 pm    Post subject: Paint removel Reply with quote
How do i go inside door jams etc
Rustynail
PostPosted: Sat Jul 19, 2008 12:40 pm    Post subject: Re: paint removel Reply with quote
Rustynail wrote:
Hello
Thanks Rustynail
I had a paint removal problem on my Sprite, the wings had so many layers of paint I almost despaired, I found paint stripper would barely remove one layer at a time, as it dried so quickly before penetrating.
The answer: apply the paint remover and immediately cover it with clingfilm to stop it evaporating, I found I could remove twice as much paint this way.
peppiB
PostPosted: Sat Jul 19, 2008 12:50 pm    Post subject: Re: Paint removel Reply with quote
Rustynail
The nylon abrasive wheels I use on the drill come in a variety of sizes and shapes to get into all those difficult places. if the drill cable is causing me problems, I revert to the cordless one instead.
Rustynail
PostPosted: Tue Jul 22, 2008 12:59 pm    Post subject: paint removel Reply with quote
Thanks everyone for your help much appreciated
Rustynail
PostPosted: Tue Jul 22, 2008 1:12 pm    Post subject: Reply with quote
Maybe because they don't last long and are very expensive. Crying or Very sad
