Paintwork
eddie
PostPosted: Mon Jul 28, 2008 9:31 pm    Post subject: Paintwork Reply with quote
Hi Guys, My 1967 Midget ( teal Blue ) has had at sometime in it's life a terrible bonnet respray. The bonnet is covered in masses of little raised speckes , I have flatted it down with 1200 grade wet and dry and it looks a lot smoother but it now has lots of swirly scratches on it, has anyone got any idea of the best way to remove them. Should I use a different grade of wet and dry and should I rub it up and down or in a cicular motion. Do I need a stronger compound than T-Cut ? I think when polished better it will look great. Advise please.
Eddie
Job-Rated
PostPosted: Mon Jul 28, 2008 11:42 pm    Post subject: Reply with quote
Have a look here...
http://www.fulciotestserver.com/VBulletin/rebelv8/showthread.php?t=2793
peppiB
PostPosted: Tue Jul 29, 2008 8:15 am    Post subject: Reply with quote
Must admit I have never heard of this clay but the results certainly look impressive. Must try it.
After flatting (using soap and 1200 wet and dry) I have always used a fine cutting compound using a blue foam bonnet (for cellulose) or white foam bonnet (for 2K) followed by polish, more polish (pink foam bonnet) and resin gloss finisher (lambswool bonnet)
PostPosted: Tue Jul 29, 2008 9:19 am    Post subject: Reply with quote
Might just move this over into the Resto - Paintwork section if thats ok.
Smile
