Morris Marina pickup
PostPosted: Sat Jul 05, 2008 6:29 pm    Post subject: Morris Marina pickup Reply with quote
Hi all
A friend has bought this Marina pickup to fettle up and use. He's on the lookout for a few bits and pieces, so I said I'd give it a mention here. Specifically he wants one or maybe two sills (passenger's side is the worst).
Are the pickup sills the same as on the saloon, or a different length/profile?
And are they available anywhere? I've seen saloon ones on ebay but not sure if they are the same or not.
Also, he's after a good s/h gearbox and a seat. I think he'd consider buying a similarly aged saloon if it had some good bits to swap over.
ta, Rick
Carcruiser
PostPosted: Tue Aug 26, 2008 11:07 pm    Post subject: Reply with quote
Looks a nice pickup. yes sills are the same as the car, as are rear arch repair sections if needed. The seats are van specific, I think the passenger tips forward so you can get at the spare wheel behind the seat under the load deck (sort of in the rear footwell if it was a car - its the same floorpan). I've got car seats in mine hence the spare wheel floats around loose int he back till a better idea comes along.
cheers
Iain
