What Are Your Engine Assembly Top Tips?
PostPosted: Wed Oct 01, 2008 5:58 pm    Post subject: What Are Your Engine Assembly Top Tips? Reply with quote
Dropped the Morris 8 engine off at the machine shop this morning, it will be done for Friday, so hopefully I'll be re asembling it this week end.
Do you have some useful tips when re-assembling an engine?
Cheers Dave
Roverron
PostPosted: Wed Oct 01, 2008 6:02 pm    Post subject: Reply with quote
Absolute cleanliness and lots of oil on the bits before you fasten them together. Clean all the threads with taps/dies before starting will really help.
PostPosted: Wed Oct 01, 2008 6:07 pm    Post subject: Reply with quote
What are you having done? bores, crank etc?
Rick (OCC Admin)
PostPosted: Thu Oct 02, 2008 7:58 am    Post subject: Reply with quote
Bores are at a maximim so having liners fitted which will take it back to standard 57mm bore, new valve guides, valve seats cut, crank reground, may have camshaft bearings fitted (non on a standrd engine) although on quick first inspection they didn't think this would be needed, block and head sufraced.
PostPosted: Thu Oct 02, 2008 11:18 am    Post subject: Reply with quote
Any tips and words of wisdom do you have regarding fitting of the cork and rope crank oil seals? Do I soak the cork and fit wet or as someone suggested boil in gearbox oil first?
looking at them in the gasket set it is hard to belive the rope and cork are ever going to be reliable seals on a spinning crank Shocked !!
PostPosted: Thu Oct 02, 2008 11:21 am    Post subject: Reply with quote
I know when I re-fitted the sump on my E83W, I left the rope seal soaking in oil overnight first
Rick (OCC Admin)
PostPosted: Thu Oct 02, 2008 12:38 pm    Post subject: Reply with quote
A decent well callibrated torque wrench, If you need one over the weekend, I can bring one from work, recently tested?
PostPosted: Thu Oct 02, 2008 1:05 pm    Post subject: Reply with quote
yeah don't make my mistake with the torque wrench - ie relying on one that hasn't been wound off back to zero when finished with on previous jobs!!
Rick (OCC Admin)
PostPosted: Thu Oct 02, 2008 2:20 pm    Post subject: Reply with quote
Dave that would be really useful if I can take up your offer.
I do have torque wrench but its 20 years old, never been calibrated , not used in anger for 10 years and I suspect will have been stored without zeroing on many occasions Embarassed !
PostPosted: Thu Oct 02, 2008 8:49 pm    Post subject: Reply with quote
no problem, pm sent Smile
PostPosted: Thu Oct 02, 2008 10:00 pm    Post subject: Reply with quote
Can't remember if the pistons fit from the bottom on the Morris 8? if they do: make sure they remember to chamfer the bottoms of the liners. They didn't when they did my Austin 10/4 and I had to make a special tool to compress the rings when I had to refit a piston at a later date (with the engine in situ,) I had fiddled about for half a day before realizing this was the only course. Mad Mad
If you tie a piece of buttered toast to a cat's back, then drop it off a high building. It will hover just above the ground rotating slowly.
PostPosted: Thu Oct 02, 2008 10:38 pm    Post subject: Reply with quote
Ah! I know that problem. You can get one hand into the crankcase to push one side of the ring into the bore but what about the other two? sides?
Even if the liner is chamfered it's a fiddle. I seem to remember trying to get a ring compressor in but for some reason that I've know forgotten this was impossible and I ended up poking around with scriber points to get the rings in. Shocked
Oh, and you've got to remember where the ring location pegs are if your pistons are so designed. Evil or Very Mad
1939 SS Jaguar 2 litre saloon
PostPosted: Thu Oct 02, 2008 10:45 pm    Post subject: Reply with quote
Did you try wrapping a little shim steel around the pistons, and sliding them through that? (Just to get you in the bore)
PostPosted: Fri Oct 03, 2008 10:15 am    Post subject: Reply with quote
Hi Buzzy,
I did something similar to that. I used a piece of steel packing banding fitted into a slot in the end of a 5/16" rod. When the rod was rotated the banding compressed the rings. Confused
Don.
Jim Walker
PostPosted: Fri Oct 03, 2008 11:18 am    Post subject: Reply with quote
From experience, my top tip would be to remember that oil (or grease) cannot lubricate where it cannot get. "Tight" fits are not good. The clearances recommended by the manufacturer allow for expansion AND lubrication. Don't rely on a tight bush or whatever to bed itself in - it will often be damaged before it does, possibly siezing. This does not apply just to engines, but to everything that rotates, slides, oscillates or any other type of bearing surface including king pins and bushes etc.
Jim.
