Posted: Sun Apr 06, 2008 1:01 pm Post subject: Brake nipples |
Does anyone know where I can get hold of some 1/2"-20 male brake nipples for 3/16" brake line? None of my usual suppliers have them listed, and actually say they dont exist. This is in spite of the fact that I had the only one I have in my hand to prove otherwise....
And before anyone says use an adaptor, on this particular application, I just cant make the space |
Posted: Mon Apr 07, 2008 7:09 am Post subject: |
Hi UJ
It is an odd size, they would be quite easy to turn from some stock hexagonal bar if you know somenone with a lathe. |
Posted: Mon Apr 07, 2008 7:33 am Post subject: |
If making a one off is what I have to do, then I will bite the bullet and do it. Its just that it feels a bit infuriating to know that they exist, and not know where they can be purchased.
I have got the same thread for 1/4" line, the question is, will this make any difference? I remember from when I used to race motorcycles that reducing line diameter used to make for grabby brakes, but havent a clue what would happen the other way. Then again, theres the question would it be noticable on a car? |
Job-Rated
Posted: Mon Apr 07, 2008 10:45 am Post subject: |
Joe, when it came to fitting a line lock to my truck, I remember we had problems trying to source certain connectors. The Amarican sizes didn't appear to be available.
Then we tried this place & they had everything...
Real Steel
Unit 9
Tomo Industrial Estate
Packet Boat Lane
Cowley
Uxbridge
Middlesex
UB8 2JP
Tel: 01895 440505
Fax: 01895 422047
email: sales@realsteel.co.uk _________________ Don't run your fingers over my truck & I won't run my truck over your fingers!
Posted: Mon Apr 07, 2008 11:22 am Post subject: |
Thanks for that one J-R. If all else fails, I'll give them a try. If I do, I just hope postage is not a ridiculous price... |
1stpop
Posted: Tue Apr 08, 2008 7:50 pm Post subject: |
I have always had a problem with brake nipples....
Everytime I get close to the nipples She always tells me to put the brakes on!!! |
Posted: Thu Apr 17, 2008 11:39 am Post subject: |
Having failed miserably to find any of these fittings, this morning I bought some Hex bar. Next week, the lathe will be fired up.... |
Posted: Thu Aug 28, 2008 7:09 pm Post subject: |
Thanks for the late reply. Since then I have turned some from the hex bar I bought.....the trouble is, they are still not fitted to the car! |
Greeney in France
Posted: Thu Aug 28, 2008 7:22 pm Post subject: |
I find "automec" great _________________ www.OldFrenchCars.com
The_ Yellow_Ardvark
Joined: 05 Sep 2008 Posts: 28 Location: Out Sude my head
Posted: Fri Sep 05, 2008 8:55 pm Post subject: Brake Nipples |
Try Frost, if they don't have them as stock they can popint you in the right direction.
Failing that Try your local Lucas shop they have helped me in teh past. |
Jim Walker
Posted: Wed Oct 08, 2008 5:02 pm Post subject: |
This is probably far too late to help in this case, but 1/2 inch 20 t.p.i. is Unified Fine (UNF).
I have never tried it, but it seems to me that it would be a simple job with a lathe to drill a 1/2 inch UNF setscrew and turn a matching taper or cup on the end. I see no reason why this would not work, nor any safety problems.
Remembering that the exception always proves the rule. I have never found a brake tube nut that was not a standard thread at the time the vehicle was built.
Making a female tube nut might be more problematic, but of course could still be done on a lathe from hexagon bar and standard taps.
Jim. |
