rubber sheet
Greeney in France
PostPosted: Thu Feb 05, 2009 10:26 am    Post subject: rubber sheet Reply with quote
Do any of you helpful chaps know from where I can get sheets of rubber that look like material, they are used to cover body holes where a rod passes through like a gear linkage or something usually quite thin but have a woven material look about them, I will try to get a photo.
Thank you
www.OldFrenchCars.com
Greeney in France
PostPosted: Thu Feb 05, 2009 8:15 pm    Post subject: Reply with quote
PostPosted: Thu Feb 05, 2009 11:33 pm    Post subject: Reply with quote
Nick,
Have a look at http://www.woolies-trim.co.uk/c-123-sheet.aspx
Art
Greeney in France
PostPosted: Fri Feb 06, 2009 8:55 am    Post subject: Reply with quote
Thanks Art I did try Woolies but they only do flat finishes and although it doesn't really look that different from a distance I would like it to be textured
PostPosted: Fri Feb 06, 2009 6:18 pm    Post subject: Reply with quote
It looks like as is sometimes used for exhaust mounting webbing - you may find some wide enough at commercial vehicle factors or agricultural merchants?
Rover P2
Morris Mini Traveller Mk2
PostPosted: Fri Feb 06, 2009 7:25 pm    Post subject: Reply with quote
Industrial belt manufacturers can do that sort of thing.
Greeney in France
PostPosted: Fri Feb 06, 2009 9:00 pm    Post subject: Reply with quote
I will give the companies a go, there is no fabric in the rubber its just the look. Citroens have it everywhere including dirt shield under wings, I have managed to get by as I had lots of bits taken off other cars but now I am running short Rolling Eyes
