want-one
Posted: Tue Mar 17, 2009 7:42 pm Post subject: royale touranger.rebuild.... now for sale! |
thought you lot might like to see my caravan (well the wife is'nt to keen on it!)
plans are to make it useable and then use it!!
want-one
Posted: Wed Mar 18, 2009 3:11 pm Post subject: |
update most of the trouble with my van is up front. damp getting in via windows and awning rails. so of with them and out with the front windows to see whats behind them
seemed worse on the off/side/front corner
but once the panels were removed the wood framing was rotton. so removed all dead wood back to good stuff and moved over to the n/s/f
it was as bad so gutted it as well
ok thats all the bad wood gone from the front next step is to start putting new stuff back in
by the way just love my toilet
thats it for today
emmerson
Posted: Wed Mar 18, 2009 7:40 pm Post subject: |
Hi wantone. I'm chairman of the Royale owners Club, and sadly, what you've got there is about the norm for all Royale models, but it's all repairable. Why not check out our website? I'd suggest using your address bar at the top of the screen, as Google doesn't seem to recognise us! You'll also find an application form for membership.
www.royalecaravanownersclub.co.uk
ATB, Emmerson |
want-one
Posted: Wed Mar 18, 2009 8:07 pm Post subject: |
hi mate, i know who you are i was speaking to you on the phone today  |
vatco
Posted: Fri Mar 20, 2009 8:38 am Post subject: |
As the man from Royal says ...........Typical but very doable.
We recently did a Touranger. Lovely vans
Have another Royale in now. Same old probs. Many vans suffer from these issues some to a lesser extent but problems around the corners are common and especially the front. It is also common to see the off side seems to suffer worse than the nearisde. And there are various theory's as to why.
We think it is because of the extra exposure while driving in our wonderful climate  _________________ Home is where you park it |
want-one
Posted: Sat Mar 21, 2009 6:52 pm Post subject: |
got abit more done on the van this week
first replaced the rotten frameing with new
then clad that with 3.4 mm plywood , used ply instead of hardboard for the lower panals
then rebuilt the seating frame that i had to break on both sides to get at the wallboard panals. decided to just remake both areas either side of the draws with new wood
all done at the bottom. moved up to the windows.
i had to remove the wallboard that was glued around the window edge as some was rotted, i dont have enough wall board to match round this area so im covering the area with new plywood then covering it with some canvas ive picked up from a picture framers. this will be glued to the ply and painted when finished, it should blend in with the roof panals.... i hope
here is the ply fitted in place ready to have the window openings cut out
just need some small sections of wall board to match down the sides of the van were it meets the front panal. then recover the window sill and put all the hardwood trim bits back on the edges.... after fitting the window though.
coming along, think its going to work out fine!!!  |
emmerson
Posted: Sat Mar 21, 2009 11:56 pm Post subject: |
| Keep going Ian, you'll get to a rally soon! Well done, mate. |
Andylad
Posted: Sun Mar 22, 2009 3:40 am Post subject: |
| Great work your photos will be a great help next week if i get to the viking, great looking van, happy days. Andy. |
want-one
Posted: Sun Mar 22, 2009 8:55 am Post subject: |
thanks guy's really enjoying myself this last week, mine it helps cos the sun's been shining
can someone please take a picture of the back of the side seating backrest area as mine has a diy hindging thing attached to the back of the seat to allow some ajustment of the backrest!
any help please? |
Barry Lord
Joined: 03 Jan 2008 Posts: 114 Location: Shropshire and Powys border
Posted: Sun Mar 22, 2009 10:06 am Post subject: |
| My 1971 Royale T125 had the same problem in the front nearside corner. I have also have a1981 Tourmaster, which seems never to have leaked, however, not even around the lantern windows . . . |
emmerson
Posted: Sun Mar 22, 2009 7:43 pm Post subject: |
Ian, after 1972 the backrest should be hinged at the top. Three hinges, front, back and one in the middle. There should also be a hinged flap on the back of the backrest which drops down when the backrest is pulled forward, thereby supporting the backrest to make it more comfortable when used as a seat. The backrest folds back to make the bed wider when used as a single bed.
Prior to this fitting the seat was too wide to sit on comfortably.
If this isn't very clear give me a ring and I'll try to email you a pic.
Emmerson |
want-one
Posted: Tue Mar 24, 2009 11:14 pm Post subject: |
here we go again....
cut window openings out and trimmed corner blocks, fitted capping and then it started to rain so up went the blue tarp as im doing all this out in the open........ i spy my little hotrod in the back ground
once the rain stopped in went the windows and awning/drip rails
still got to finish the side panals where it meets the front, but ill have to find some matching wall board from somewhere.
moved on to the area over the wall cabinets, a repair by the last owner to a leaky lantern window didnt look very good and had been coverd with wallpaper. thought i could do better so ripped the old repair out and removed the wallpaper.
getting late so give up at this stage
more to come  |
want-one
Posted: Fri May 01, 2009 5:11 pm Post subject: |
this van is now up for sale....done a bit more to it and will continue to do work on it, but it has to go, i need the space!
want-one
Posted: Fri Jan 21, 2011 7:04 pm Post subject: |
| this van has now been sold! thanks |
