Widening the wheel base on a 67 MGB GT
MGB Yank
PostPosted: Wed Oct 21, 2009 9:13 pm    Post subject: Widening the wheel base on a 67 MGB GT Reply with quote
I wanted to widen the wheel base on my B by about an inch or so. Any advice on how to accomplish this?
PostPosted: Thu Oct 22, 2009 2:49 pm    Post subject: Reply with quote
You can fit the after market wire wheels and you may have to remove some of the rear wheel arch rebate.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
victor 101
PostPosted: Thu Oct 22, 2009 4:10 pm    Post subject: Reply with quote
You used to be able to buy spacers with extended bolts, the spacer was a disc with slotted holes to fit different PCT's and the bolts had a head the depth of the spacer with a thread on the inside that screwed on your exsisting wheel studs, the spacer stopped them unscrewing and you put your wheel on as normal. Obviously no good if you have wire wheels.
PostPosted: Thu Oct 22, 2009 5:36 pm    Post subject: Reply with quote
Spacers and wide wheels put extra strain on the wheel bearings and steering joints which may be marginal anyway given the car's "pedigree"
Rover P2
Morris Mini Traveller Mk2
Rich5ltr
PostPosted: Thu Oct 22, 2009 10:01 pm    Post subject: Reply with quote
What are you trying to achieve?
MGB Yank
PostPosted: Fri Oct 23, 2009 2:03 pm    Post subject: Reply with quote
I wanted to widen the wheel base to accommodate an added design feature. I do have and want to keep my wire wheels. I wanted to add about an inch around the fenders, and build up the metal coming up the top side.
I found this picture on the web and love the way the car looks.
victor 101
PostPosted: Fri Oct 23, 2009 10:26 pm    Post subject: Reply with quote
Maybe it would be possible to have your wires rebuilt with a wider rim.
Rich5ltr
PostPosted: Sat Oct 24, 2009 8:09 pm    Post subject: Reply with quote
Humm not to my taste, looks like an attempt at a Sebring MGB but lacking in taste and I really think that modern low profile tyres on classic cars look awful but that's just my opinion. Each to their own eh? Look for Sebring MGB/MGC wheel arches and you'll get what you want.
MGB Yank
PostPosted: Mon Oct 26, 2009 2:37 pm    Post subject: Reply with quote
I agree, i am not looking to put on new rims i just want to add the trim around the fenders and keep my wire wheels. But if I add the trim i think my wheels will be too deep into the well?
PostPosted: Mon Oct 26, 2009 2:43 pm    Post subject: Reply with quote
yup I think it would look a bit odd, with flared arches and standard wheels and track. If you're going down the modification route, how about some big Minilites, a la Sebring? As others have said, I'd be wary of using spacers due to the loads etc
Rich5ltr
PostPosted: Mon Oct 26, 2009 3:49 pm    Post subject: Reply with quote
Here you go, this is the way to do it!
Laughing
MGB Yank
PostPosted: Mon Oct 26, 2009 8:51 pm    Post subject: Reply with quote
Much too grandiose for me. I am looking for something a little more subtle. I wanted to extend flare about an inch at a maximum. Thus looking into the wheel spacers, figuring if I could get an additional half to three quarters of an inch I would be ok.
MGB Yank
PostPosted: Mon Oct 26, 2009 8:53 pm    Post subject: Reply with quote
I did find some information on cutting out VW rabbit front fenders and Dodge Omni rear fenders to achieve the desired look, and experience?
