Posted: Tue Nov 17, 2009 5:53 pm Post subject: Clearing a fuel tank pick-up |
I've been looking into a fuel supply issue I've got - the mechanical AC pump works ok, and the line to the tank blows through ok. I think the problem is in the tank - with the tank removed and on the floor, it looks like there is a steel pick-up pipe that enters the tank, curves up, then down to the base of the tank, with what must be some kind of filter attached to it. I've tried blowing compressed air into the tank outlet, but none seem to be getting through, and I've tried poking wire (an old choke cable) in, with equally unimpressive results.
Anyone have any other ideas for clearing a blocked pick-up, when the end of the pipe and filter is inaccessible???
thanks, R _________________ Rick - Admin
Posted: Tue Nov 17, 2009 6:23 pm Post subject: |
Are you sure pickup pipe is not removable? Can you see end of through tank-level sender? Otherwise send high pressure air through - it may blow gauze/filter off end of pipe and then just rely on an inline filter and sediment bowl
Otherwise it is down to cutting an access hole and soldering back on or another tank. _________________ Rover P2
Posted: Tue Nov 17, 2009 6:52 pm Post subject: |
Have you tried a vacuum cleaner sucking on the pipe ? |
Posted: Tue Nov 17, 2009 7:06 pm Post subject: |
Rick, have you tried dropping a magnet on a piece of string or stiffish wire (the type of curtain wire used with lace curtains etc. is good) down the filler hole into the tank to see if your problem is rust scale?
Many older cars suffer from that, particularly if the tank has been left empty for some time, letting damp air in. It is often amazing how much rust can collect in a tank and these particles, being flat scale, can gather to form a good seal.
I had similar trouble and I drove around for some time with the magnet in, cleaning it from time to time. Eventually it picked up no more rust and I removed it. That was 25 years ago and I have had no trouble since! _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
Posted: Tue Nov 17, 2009 8:50 pm Post subject: |
Can you get a pressure washer into the tank, through the sender to aim at the pickup, then on hot or steam, give it a good going, also some decent detergent incase it is all gummed up?
Other option, some decent solvent maybe?
john-saab
Posted: Fri Nov 27, 2009 10:04 am Post subject: |
There is a more drastic measure if you can get to the pipe inside of the tank..cut it off and attach a new hose with a new filter. _________________ Rust Junky & oil addict. |
