buzzy bee Guest
Posted: Tue Jan 09, 2007 11:22 pm Post subject: Long shot but worth a go! |
On the brake drum slave cylinder, there are two pistons hel in place with cotter pins. If you remove these pistons, there is a slot in the end with a roller, these slots are on an angle as is the fitting on the end of the cable that controlls them. Do theses to angles go opposite ways, contridict each other (is that the right word) or do the angles both go the same way?
Very hard to explain, but have no pictures, the manual and the parts book doesn't help either, but have got to get it right as the shoes won't move to the right extent other wise!
Dave  |
rustyreks Guest
Posted: Wed Jan 10, 2007 6:12 am Post subject: position of the pistons |
| I have a ford 8 and 10 manual which has a picture of the brake set up lthe shortest side of the piston on both top and bottom is facing the front of the brake drum sitting on the rollers the longest side on both pistons is facing the rear of the brake drum doesnt engage with the rollers at all hope that helps photo would have been easier only new not sure how to do that rustyreks. |
buzzy bee Guest
Posted: Thu Jan 11, 2007 5:34 pm Post subject: |
Thanks for the reply from rustyreks and he also sent me the following picture, which I found very helpful, and said I would put it up here.
