Posted: Mon Nov 23, 2009 4:25 pm Post subject: |
Thanks Rick, PM sent.
Here are the mirror stems:
The stems are approx. 4" long. _________________ Richard Hughes |
Posted: Mon Nov 23, 2009 6:09 pm Post subject: |
Standard Desmo Boomerangs - the mirror head which come in 3 oblong sizes and a round one has a course threaded capitivated loose stud with a flat on it to match the, in effect, D shaped hole in the stem.
Tex or Magnatex mirror heads will also fit reasonably well if the Desmo nut is used _________________ Rover P2
Posted: Sat Nov 28, 2009 4:16 pm Post subject: |
I found this and thought you might be interested in it.
Not for the faint hearted _________________ ROVER
One of Britain's Fine Cars |
Posted: Sat Nov 28, 2009 5:04 pm Post subject: |
Saw it at Hoghton Tower show about 3yrs ago, looks as if he has done a bit more to it.
The wheel is altered and I don't seem to remember the spider web.
Keef
Joined: 13 Jan 2008 Posts: 371 Location: Sheerness Kent UK
Posted: Sat Nov 28, 2009 5:55 pm Post subject: |
Rick wrote: | Looks like a Mk2 A40 dash in there |
Yep, an early pre-imitation-wood one.
Also has A40 seats. _________________ Keef - Sheerness Kent UK
clascar
Posted: Sat Nov 28, 2009 9:08 pm Post subject: |
It might be worth changing the oil in your gearbox, I did my Rapier and the difference was incredible. make sure you put the correct oil in. _________________ When I exhibit a car I get the Shudders. People queue up to tell me.
You should have done that, you should have done this. Ray |
Posted: Sun Nov 29, 2009 7:27 pm Post subject: |
Penman - 'Austintatious' was featured in the OC magazine a couple of years ago. Not to my taste, but I can certainly appreciate the work that has gone into it. I particularly like the flying A shaped indicators at the front
Rick - Certainly not!!
Ray - I have been told that the most likely cause of the non-existant synchro on 3rd and 4th gears is broken/rusted synchro springs, which are prone to breaking when the car is parked up for a long time. At some point I will definately replace the 'box, at the moment I'm just double-declutching it.
Spent the afternoon straightening out the original grille as it is cheaper than getting a new one, it's a slow process as the metal was pretty deformed in an accident many years ago I still need a grille badge though.
Last week I had a lot of trouble with misfiring, so on Friday I changed the points, plugs, rotor arm, condenser, distributor cap and also a better 2nd hand distributor as the one that was on it had play in the rotor shaft. Everything seemed fine until returning home last night, it started misfiring and cut out in a layby about two miles from home. I dismantled the carb and blew through the jets to get me home, then this morning it cut out at a busy roundabout so had to do the same thing. There wasn't a huge amount of dirt in there, but it looks like the recently fitted filter has failed I should change the petrol tank, but don't really want the car off the road. _________________ Richard Hughes |
Posted: Mon Jan 11, 2010 1:09 pm Post subject: |
Some recent pics:
And on a slightly less-snowy day
The car has been totally reliable recently, starting first time every time no matter how damp, and trudging through the snow no problem. The only recent problem I've had is that one of the dynamo brush springs snapped and the dynamo stopped charging, which resulted in a nail biting drive home from Pitsea, at night, using sidelights right up until the last moment
All fixed now though _________________ Richard Hughes |
Keef
Posted: Mon Jan 11, 2010 1:26 pm Post subject: |
Richard H wrote: |
The car has been totally reliable recently |
They are good little motors.
Some nice pics there as well. _________________ Keef - Sheerness Kent UK
Posted: Fri Mar 05, 2010 8:41 pm Post subject: |
I haven't updated this for a while. Touch wood, the A35 is running brilliantly, I used it all through the winter and had no problems with it, apart from leaving it parked outside one night with no antifreeze in it Went to start it in the morning and a core plug had popped. I was able to change it and luckily the engine escaped damage. A lesson learnt I think.
Recently I heard that lee1984 from this forum was breaking an A35 for spares. He doesn't live far away, so I went over for a look and was able to get loads of parts I'd been after for ages, including front and rear bumpers with overriders, front grille with badge and chrome surround (horseshoe) rear reflectors and flying A and base. Spent most of today fitting the parts:
Before: Bumper twisted and bent from an accident and from a tow rope, I spent some time straightening out and painting the original grille a few months back but never got it good enough.
Before: Twisted front valence.
After: Straightened out with molegrips, not perfect but an awful lot better.
Rear bumper fitted, and new reflectors replacing the damaged and missing originals, I was able to change the rubbers for better ones as well. Sorry about the picture quality.
New Flying A fitted, attatched to a very good base I already had, unfortunately it was a pain to fit due to the bonnet catch being twisted out of shape - I can only assume something went over the bonnet in the accident
And the finished result. (I know the car needs a wash!) I removed the numberplate (original Hills plate) and polished up the aluminium digits and border - they came up a treat
Another recent job we did was change the gearbox. Early last year I spotted a late Minor gearbox on Ebay, 50p start, condition unknown. It was in Southend, and I ended up winning it for 50p! When we came to collect the man said forget about the 50p
Anyway a couple of weeks ago we decided to fit the "ribbed" case 'box, together with a 1098 clutch and flywheel. The original clutch was slipping badly by this point, and turned out to be down to its rivets The car is now completely transformed though, the gearbox turned out to be in excellent condition, and coupled with a new clutch make it lovely to drive
Jobs to do in the near future include: Change the rear hub seals as they are leaking, and change the rear brake shoes. A couple of areas of welding have to be done before the MOT (May), at the rear of the N/S sill and in the boot floor. Oh and check and top up the front shock absorbers.
If all goes to plan, she should be at the Austin/Morris day at Brooklands on Sunday _________________ Richard Hughes |
andycars
Posted: Sat Mar 06, 2010 1:11 pm Post subject: |
What a transformation! It's nice to see a car like that still being used as Austin intended. A real stroke of luck with the gearbox too; when your replacement is of unknown condition it's a lot of hassle to fit only to find it's no good (happened with my palm green A35 once). Glad that didn't happen to you.
Andrew |
Keef
Posted: Sat Mar 06, 2010 1:46 pm Post subject: |
Nice work Richard!
Makes it look even smarter than before; and it wasn't bad before. _________________ Keef - Sheerness Kent UK
