Posted: Sat Aug 08, 2009 9:17 am Post subject: |
Yes, I'd check the distributor cap for cracks. _________________ Richard Hughes |
Posted: Mon Aug 10, 2009 1:23 pm Post subject: |
Had a similar problem years ago with an A35. Coil mounted on the dynamo. The clamp around the coil had cracked the coil case and it was slowly loosing oil. Eventually it displayed exactly the symptoms described.
Only found it because the vehicle appeared to have an oil leak where there was no oil!!
PAUL |
TTotal
Joined: 30 Aug 2008 Posts: 90 Location: Titchfield Common, Fareham
Posted: Mon Aug 10, 2009 7:07 pm Post subject: |
Wedding went very well (see my Facebook page for pics!)
Interesting thoughts about the distributor area...
Cheers all
John  _________________
Posted: Mon Aug 10, 2009 7:19 pm Post subject: |
Hi John
How about joining the oldclassiccar facebook group (It's called Oldclassiccar)
I'm Richard Hughes on there  _________________ Richard Hughes |
Posted: Tue Aug 11, 2009 4:12 pm Post subject: |
I don't think - up to now - that a clogged air filter has been mentioned. An engine needs lots of air as well as fuel and will not run well with a shortage of either. You say "pulling the choke out makes no difference", which it probably won't if the air filter is clogged. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
TTotal
Posted: Tue Aug 11, 2009 9:03 pm Post subject: |
(Wahoo still married after 6 days!)
Air filter eh? Must have a peak this weekend. THANKS!
TTotal
Posted: Mon Jan 11, 2010 10:24 am Post subject: |
and.......... months later!
It was a carb full of water!
Cleaned out fuel pump, carb, tank and fitted new filter. Also new rubber seal on filler cap just in case.
2,000 miles later all fine.
He goes on and on, brilliant too in the snow as tyres are narrow.
