Filthy petrol tank
Goto page Previous  1, 2
clascar
PostPosted: Thu Mar 04, 2010 8:45 pm    Post subject: Reply with quote
2 things, try a short length of chain instead of gravel etc. Secondly it may be a good candidate for an electrolysis bath, that's where the one off my P4 is going.
When I exhibit a car I get the Shudders. People queue up to tell me.
You should have done that, you should have done this. Ray
PostPosted: Fri Mar 05, 2010 12:09 am    Post subject: Reply with quote
I cleaned mine out with an industrial vacuum cleaner.
Stuck the end in to a corner, up ended the tank to that corner a block of wood rattled on the tank for a couple of minutes then washed out with parafin.
Looked quite clean but time will tell when the car is back on the road.
Artiegee
PostPosted: Fri Mar 05, 2010 4:07 pm    Post subject: Filthy petrol Tank Reply with quote
Well thanks very much for all your ideas.
I have got the tank off so will insert a length of chain and rotate it for a while to dislodge the rust, I will replace the tank and insert the magnet for any remaining residue and if necessary insert an inline filter.
Thanks folks once again.
PostPosted: Fri Mar 05, 2010 4:22 pm    Post subject: Reply with quote
Sounds ok so long as there is no recent fuel vapour still in there, I've heard of tanks going up when a spark from the vac's motor meets the vapour.
PostPosted: Fri Mar 05, 2010 4:29 pm    Post subject: Reply with quote
WOW! Where do I remember reading of the incident where a chap vacuumed out his tank and burnt out his garage, his car and almost his neighbours!
I'm not sure about industrial vacuum cleaners, but normal domestic ones pass the incoming air over the (generally sparking) motor to cool it. WHAM!
Hardly recommendable I would think!
Jim
Apology Rick. I have just clicked "edit" to add this bit. We must have been typing our response at the same time! But I think a repeat can't do any harm.
PostPosted: Fri Mar 05, 2010 11:08 pm    Post subject: Reply with quote
Sorry forgot to mention
The tank had been empty for about 30, or more, years
I should have mentioned, make sure the tank is purged of any fumes.
Roger
petelang
PostPosted: Fri Mar 26, 2010 4:58 pm    Post subject: Reply with quote
Serk Marston do a good job on fuel tanks and not too expensive. They clean insides with chemicals.
Try them for a price
Page 2 of 2
