Red Rubber Grease
bob2
PostPosted: Thu Aug 12, 2010 7:53 am    Post subject: Red Rubber Grease Reply with quote
Could anyone please tell me where I can purchase red rubber grease from?
I have not found any locally and would like to buy some.
I need it for the white wall trims as the instructions said to put red rubber grease in between them and the tyres.
Any ideas or links?
remember I am in Malta so items must be posted!!
MONTBREHAIN
PostPosted: Thu Aug 12, 2010 7:44 pm    Post subject: Reply with quote
I used some to rebuild the brake and master cylinder on my bedford , its not expensive and comes in a fairly small tube. PM me and I will try to find and send you a tube over... "MO"
A vehicle can be restored at any time, But is original only once !
michael1703
PostPosted: Thu Aug 12, 2010 7:46 pm    Post subject: Reply with quote
you can get it in a fairl big tub made by castrol, more than a fiver but less than 8 quid from memory
or ebay
http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m570.l1313&_nkw=red+rubber+grease&_sacat=See-All-Categories
bob2
PostPosted: Fri Aug 13, 2010 7:28 am    Post subject: Reply with quote
Ok managed t ofind some locally yesterday afternoon from the local EBC/Silkolene agent!!
I never used it on the rubbers of master cylinders etc but will most surely start using it now I have a 500g tub!!
Will surely come in handy and it was about 8 euros so quite cheap too!!
Thanks for the input chaps!! Wink
JohnDale
PostPosted: Wed Dec 01, 2010 4:10 pm    Post subject: Re: Red Rubber Grease Reply with quote
Any ideas or links?
The sellers of white wall flaps tell you to use red rubber grease but all that happens is that they fling the grease off & the flaps wear a groove in the tyre, at least they do on radials. Maybe better on cross plies with the harder wall but I haven't tried that - I gave up & purchased white wall tyres. Cheers,JohnDale.
1976 Ford Granada Ghia.
bob2
PostPosted: Thu Dec 02, 2010 8:42 am    Post subject: Reply with quote
You have to put it on on a regular basis though or is it still the same?
what if you tried sealing the edge all around with some sort of silicone so the rubber grease cannot escape through?
tyres with white walls or white bands are a little too expensive over here and since mine are 13 inch never managed to find any for sale locally, 14 inch are obtainable since thay are fitted to a lot of mercs 123s and 124s!!!
Oh and I too have radials fitted with the inserts!!
so will have to watch out for what you have pointed out, if I find out they r damaging the tyres the cheapest would be to take them off and leave the tyres without them!!
