tribsa
the general
PostPosted: Wed Sep 22, 2010 9:33 am    Post subject: tribsa Reply with quote
Hi,
i am building a tribsa and need some info can any one help please.
i am using a triumph 5T engine and a bsa A10 gear box in a A10 frame.
Can any one tell me what primary chain cases to use i will be running an altanator and a norton clutch.
any help with this would be most appreciated more importantly will save me a lot of time and searching.
thanks guy's and of course girl's.
Razz
Nic Jarman
PostPosted: Thu Sep 23, 2010 2:06 pm    Post subject: Reply with quote
My Triton had a 6T bottom end with a Norton gearbox and it had a triumph chaincase.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
the general
PostPosted: Thu Sep 23, 2010 2:33 pm    Post subject: tribsa Reply with quote
Thanks for that info,
triumph chain cases are to long to fit in the A10 frame so i guess i will have to cut them down as i cant move the engine forward any further.
thanks again.
PostPosted: Sun Oct 03, 2010 2:18 pm    Post subject: Reply with quote
I spotted a Tribsa in the Isle of Wight last week. It had a 6T engine and chaincase, though I did not take notice of the gearbox fitted. It would probably have been Triumph or I think I would have noticed the difference. I did notice the engine must have been closer to the front down-tube, because the Triumph front pipes fitted reached further forward (past the down-tube) than they would in a Triumph frame.
Jim.
lostintime
PostPosted: Mon Aug 27, 2012 2:18 am    Post subject: Re: tribsa Reply with quote
[quote="the general"]Hi,
I built one, 1967 to 1968. I used a BSA A10 chaincase. I also used an alternator.
I used a BSA gearbox, Triumph clutch, but that will make no difference to the chaincase issue.
Do you have the engine plates?
