Bob T
Joined: 16 Nov 2010 Posts: 128 Location: Sudbury, Suffolk
Posted: Wed Apr 20, 2011 6:40 pm Post subject: Axle tramp on my Morris 8 |
I have a Series i 1936 Morris 8 that has just been recommisioned after 40 odd years. Generally all has gone well but in reverse there is severe axle tramp when moving off, it happens in first as well but noy so violently.
I have checked the u bolts holding the axle to the springs, can anyone suggest what else to check, please ?
Bob |
Farmer John
Posted: Wed Apr 20, 2011 9:22 pm Post subject: |
Hi Bob. Most likely that your car is suffering massive clutch shudder, with a mechanical clutch linkage there can be a point when you begin to engage the clutch the engine moves on it's mounts it releases the clutch and the next thing you kow you have a never ending lurch or shudder. The most obvious symptom will be the gear lever jumping around like a demented animal.
Hope that makes sense, but it is necessary to know why you need to be checking your engine and gearbox mounts, as "windup" needs to be absolutely minimal. The clutch linkage needs to have no freeplay in any of the joints.
The axles will not stand much of this shuddering, the hubs might not either.
The clutch plate or pressure plate will contribute as well but if they work perfectly in first gear then head for the mounts.
Axle tramp involves the rear wheels losing traction, as when you attempt to reverse up a hill with loose gravel, and is not always cureable.
John |
