Morris 8 coils and sparks
steammart
PostPosted: Sun Apr 17, 2011 6:09 pm    Post subject: Morris 8 coils and sparks Reply with quote
I have tried a few different way to get me morris 8 series one to give me a spark, but to no success. I have got a new coil, the distributor is all ok as far as i know. but cant get a new spark.
I have tried running a live directly to the coil and distributor but still no spark, any ideas please? Its driving me nuts Confused
Martin
PostPosted: Sun Apr 17, 2011 6:40 pm    Post subject: Reply with quote
Contact breakers dirty or LT lead to dizzy broken.
Condensor faulty or points fixing shorting is Dizzt a Lucas DKA with Bakelite baseplate as these have their peculiar problem
Rover P2
Morris Mini Traveller Mk2
steammart
PostPosted: Sun Apr 17, 2011 7:43 pm    Post subject: Reply with quote
i have a spark at the points, and there is a fibre washer under the points.
cheers
Churchill Johnson
PostPosted: Sun Apr 17, 2011 10:24 pm    Post subject: Reply with quote
have you tried removing the ign coil ht lead from the distributor cap and holding near to earth on the engine then open the points with the ign on and you should see a big spark from the coil lead if not have you replaced the coil recently if so is it the correct one, if you get a good spark then look very carefully at the cap is the centre carbon still in it, if ok the cap may be cracked.
PostPosted: Mon Apr 18, 2011 9:33 am    Post subject: Reply with quote
On a Volvo 121 I had years ago, from time to time it would just cut out. There'd be a spark at the points but nothing at the plugs. In the end I found that the centre bush in the dizzy cap was, over time, working its way back into the cap and losing touch with the rotor arm. A gentle pull against the spring that the bush is fitted to, would restore things.
PostPosted: Wed Apr 20, 2011 6:54 pm    Post subject: Reply with quote
My 8 packed up and it was the condenser. Disconnect the condenser and the car should tick over but not much else. If it does not start then it is something else. I do not remember a fibre washer under the points but I will have a look. Do you have a multimeter?
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Wed Apr 20, 2011 7:14 pm    Post subject: Reply with quote
OK there is a large fibre washer under the moving bit of the points. If it is sparking then it is not shorted out. I could not get a decent condenser so I put an electronic ignition amplifier on my 8 so now it purrs like a kitten with a tin of nuts and bolts tied around its neck. Confused
Make sure the coil is wired the right way.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
steammart
PostPosted: Mon Apr 25, 2011 12:31 am    Post subject: Reply with quote
thank to all those that replied, she is now a runner, even tho i had a spark at the points, they were not opening and closing correctly, so new points and a fiddle with the carb and he presto.
cheers
Martin
PostPosted: Mon Apr 25, 2011 9:56 am    Post subject: Reply with quote
My Rover P2 16 has the DKA6 dizzy and I had the same problem - the points heel was actually badly worn comparing to a new set and wax had leaked out of the condensor. It was also missing a parke every now and again causing a backfire
Rover P2
PostPosted: Wed May 04, 2011 7:39 pm    Post subject: Reply with quote
A little late now probably. But the contact between the distributor body and engine block always seems to be overlooked.
Too much resistance will reduce sparking voltage at the coil. The MAXIMUM voltage drop between distributor body with ign. on and points closed should not exceed 0.2V. The same across the closed points. Anything more usually causes bad starting though the engine may run quite well once started because the battery voltage rises when the starter motor disengages.
There SHOULD NOT be much of a spark when the points are seperated manually. A "healthy" spark there usually means a very unheathy condenser.
The engine bonding (earth) link is also an ignition voltage killer, and a significant voltage drop between engine and battery represents voltage "robbed" from the ignition etc. while the starter is cranking the engine.
