Can you Indentify this JacK?
PostPosted: Mon Apr 02, 2012 2:23 pm    Post subject: Can you Indentify this JacK? Reply with quote
I think someone once suggested to me that the jack in this tool kit was originally used in Austins. If so or even if you think of some other car that was supplied with it, can you tell me if it and its handle were originally painted red?
(My question really only applies to pre-war vehicles.)
Thanks,
PostPosted: Mon Apr 02, 2012 4:43 pm    Post subject: Reply with quote
I think it is going to be one of those cars with a removable panel in the floor in front of the front seats and the bit sticking out from the jack was inserted in a hole in the chassis.
The jack could then be wound up and down while in the car if it was raining.
I had a car fitted like that but am not sure which one it was.
Austin Ten
Austin Eight
Rover 12 or 14 (6cyl)
Morris E (I know you said pre-war but I am trying all I have had around that period)
PostPosted: Mon Apr 02, 2012 4:58 pm    Post subject: Reply with quote
Thanks Penman.
In the SS it slots into a square section welded to the dumb irons and chassis legs at the rear.
Although the photo doesn't show it, the arm has the cross section of an "I" beam.
Julian
PostPosted: Mon Apr 02, 2012 6:53 pm    Post subject: Reply with quote
OK, I recognise the oil can, adjustable and screwdriver as my dad had all of these in his garage when I was a lad.
Prior to me being born he owned a Rover, so Looking at Penman's post I think we can be 99% certain that they are Rover tools. I remember that his Rover had a 'free-wheel' in the drive activated on the over-run if that helps?
Julian.
PostPosted: Mon Apr 02, 2012 8:34 pm    Post subject: Reply with quote
Same jack as my Rover 16 - 1938. As said its jacked up through a trap door in the floor boards in front of each front seat.
You still have to get soaking wet to get it from the boot and retreive the spare wheel from the boot lid compartment Wink
Rover P2
Morris Mini Traveller Mk2
Hi Julian,
Well it adds to the story.. and I appreciate the reply.
Thanks,
Peter Wink
victor 101
PostPosted: Thu Apr 05, 2012 5:43 pm    Post subject: Reply with quote
Looks the same as the tool kit in a 1948 Jaguar Mk4 2.5 , almost out of time on ebay.
PostPosted: Fri Apr 06, 2012 10:30 am    Post subject: Reply with quote
Yup! There wasn't much change pre-war to immediate post war.
welshrover
PostPosted: Fri Jun 01, 2012 10:04 pm    Post subject: Reply with quote
fitted to the hillman minx series v too
PostPosted: Fri Jun 01, 2012 10:31 pm    Post subject: Reply with quote
.... And fit the wheel, unless you could do that from underneath/behind the hub.... I think, just wear a coat....
