JC T ONE
Posted: Mon Sep 10, 2012 6:01 pm Post subject: Water temp gauge dont show correct temp |
Hi all,
My water temp gauge dont show the correct temp
I have tried several different senders (std Mini items) but the needle only moves a little bit, when it gets hot.
If I unplug the wire on the sender, and stick it direct on to the engine block,
the needle then moves nice and evenly all the way up to 110 degrees,
so I guess I have the wrong sender ?
The gauge is a 2" (52mm) Smiths, half scale & original 1973 model, part no TC4308/00, the scale reads " 30 - 75 - 85 - 110 "
I have been told me there are different senders, for some of the Smiths temp gauges, one guy mentioned 4 different
so who can help ?
michael1703
Posted: Mon Sep 10, 2012 8:27 pm Post subject: |
you can calibrate certain smiths gauges, on the back are two small sticky circles, take them off and you can insert a small flat bladed screwdriver and tweak them
JC T ONE
Posted: Tue Sep 11, 2012 9:53 am Post subject: |
Hi Michael,
didnt know that thanks for the heads up
Mine is a bit different, and I have found out that its defently a Smiths aftermarket accessorie.
I am sure its not connected to any volt stabilisor, I will try to bypass it, and see what reading I get ? _________________ http://www.eurods.eu/wp/index.html |
JC T ONE
Posted: Wed Sep 12, 2012 11:26 pm Post subject: |
I was in the garage tonight, and checked the spare gauge I had (100% identical) .
connected it to 12 volt, and put the sender in the kettle, and it came up to 85/90 degrees.
I then pulled back the dash, to check if my gauge was connected to the stabilisor ?
It wasnt, it had 12volt directly to the gauge, I then tried it with 5 different senders, but it still wouldnt go above 40 degrees.
So my thought are = maybe there are TOO much resistence in the wire, going from the sender to the gauge in the car ?
What I dont understand is that it does go ”full scale” = 110 degrees , if you connect the sender wire direct to the engine block .
will investigate tomorrow, too tired now. _________________ http://www.eurods.eu/wp/index.html |
Minor1965
Posted: Fri Mar 06, 2015 11:40 am Post subject: |
| JC T ONE wrote: | I was in the garage tonight, and checked the spare gauge I had (100% identical) .
will investigate tomorrow, too tired now. |
Hi JC T One,
I have the same problem with a Smiths Temp Gauge. Tried to fit a resistance in the range it should give a reading somewhere between 40 and 110 degrees. But sticks on 40. Resistance = 0 will give full scale. same as yours.
Did you solve the problem?
Thanks for the reply. |
