Austin 80
Joined: 06 Feb 2013 Posts: 12 Location: Canvey Island, Essex.
Posted: Thu Feb 07, 2013 11:04 pm Post subject: 1932 Austin 7 rear luggage rack |
Dose any one Owen a Austin 7 Luggage rack that can help me.
I would like to make a Luggage rack for my 1932 Austin but I need some sizes so I can get start on the drawing first.
Can any one Help? |
OuBallie
Posted: Sun Mar 03, 2013 10:21 am Post subject: |
Do you still need dimensions?
I am restoring a 1935 Ruby.
Geoff - Coffee time
Edit: Finger problem this morning _________________ Too many hobbies, not enough time!
1935 Austin Seven Ruby ARQ
1957 Austin A35 2-door
1967 Morris Minor 2-door
Model Engineering |
Austin 80
Posted: Sun Mar 03, 2013 10:46 am Post subject: Luggage Rack |
Hi Geoff?
Yes that would be great I think I can work out a lot of them but it's the main ones like steel size and the hight X width.
I don't think I am far from you I'm in Essex
PS I have some good Photos of the Rack.
Regards Brian |
OuBallie
Posted: Sun Mar 03, 2013 1:35 pm Post subject: |
Hello Brian,
Here goes with dimensions:-
Width - 26"
Depth - 13"
The 'openings' are 5.1/2" wide by 5" deep
The frame is 1" x7/16" channel section
There is a 3/4"x3/4" channel section under the centre bar, spot welded on.
Note the taper on the top 2.1/2" reducing o/a width to 25.1/2"
Hope this makes sense.
I've done a New Member post, with link to my photos.
Geoff _________________ Too many hobbies, not enough time!
Model Engineering |
Austin 80
Austin 80
Posted: Sun Mar 03, 2013 8:07 pm Post subject: |
Okay but don't wear it out it is 80 years old. Regards Brian |
OuBallie
Posted: Mon Mar 04, 2013 10:27 am Post subject: |
Brian,
I so like you car, and notice that the starter handle is at 9 o'clock, where it should be. I wonder how many owners know the reason why.
Your model was never fitted with a luggage rack as standard.
The Ruby & other Jewel models had them as standard, stowed behind the spare wheel cover.
From what I've gathered, up to the Jewel models luggage racks where after market parts, so you could design your own, hence the variety on Pre-1935 cars.
Model Engineering |
