welder
Joined: 26 Nov 2007 Posts: 265 Location: North Warwickshire
Posted: Tue Jul 17, 2012 10:19 pm Post subject: |
The wedding trip and the wedding itself went very well indeed thanks, Rick. It was a joyous occasion.
The Old Morris didn't miss a beat and everyone wanted to be photographed in or near to the car. I was a very proud and rather relieved man.
Truth be told, I can now relax and enjoy the car for what it is. A motoring anachronism and a thing which brings me a sort of smiling, benign inner feeling.
I offer my thanks to everyone on this forum who offered advice, encouragement and information. Invaluable and freely offered. Good people.
Please don't think that the blog ends here. The car's still not charging...............
Ian |
Bugly
![](images/avatars/1849199000498046008f448.gif)
Joined: 25 Jan 2009 Posts: 65 Location: Darwin, Australia
Posted: Sun Aug 05, 2012 1:13 pm Post subject: |
welder wrote: |
Ian |
Psst ... wanna know a good trick? Try a bit of COCA COLA splashed over the generator ...
Hey Ian, a great story. So glad it all came together in the end, thanks to a lot of good advice from lots of forum members.
Bugly |
welder
Posted: Tue Aug 14, 2012 10:10 pm Post subject: |
Bugly wrote: | welder wrote: |
Ian |
Bugly |
Bugly, thank you. You're right about the members of this forum. Good advice, freely given.
As regards the Coca Cola cure for the dynamo....I shall try more conventional methods first but I shall reserve the right to try your "trick" if all else fails.
Ian |
welder
Posted: Wed Sep 05, 2012 9:27 pm Post subject: |
Well, here I am again, hoping to pick brains for further information. A few weeks ago Old Morris started to display all the symptoms of a blown head gasket, steam from the exhaust, bubbling in the radiator and a misfire whilst under load. Upon removal of the spark plugs I noted water on numbers 2 and 3. Not good.
No problem I thought. I had a spare top-end gasket set and it was a matter of minutes to whip the head off. Nothing wrong with the gasket but some sixth sense told me to check the castings in the area of cylinders 2 and 3. Head is fine and true, checked with marking blue on a surface plate. Oh dear, a hairline crack between said cylinders, in the block. The crack appears to run all the way to each of the centre two liners so no telling how extensive it is.
I have a spare block with slightly marked bores and my intention is to have this block sleeved and bored plus 40 thou so that I can use all of my existing engine's internals in this "new" block. Existing engine is/was a recon unit and, as it's a Series E unit, has shell bearings and so on, making it easier, to my mind, to work on than the white-metalled type of engine/crank.
Can anyone commend an engineering shop to carry out the sleeving and overboring that I shall need? Ideally in the West Midlands but not necessarily. I'd be happy to travel to anywhere that can be trusted with this work.
Ian |
Posted: Wed Sep 05, 2012 9:54 pm Post subject: |
Hi ian
My m8 block was re sleeved by Dave Ruston Engines in Stoke on trent, I bought the liners from Westwood liners, they stock the m8 liners as a standard line.
welder
Posted: Wed Sep 05, 2012 10:57 pm Post subject: |
ukdave2002 wrote: | Hi ian
Dave, thank you. I shall Google both. Stoke isn't far from Brum and, for me, recommendation is more important than location.
Ian |
welder
Posted: Tue Nov 27, 2012 11:14 pm Post subject: |
I recently bought three Morris 8 engines off eBay. Well, I say engines...these look like they've been used to anchor a canal boat, for some time.
Anyway, one of these devices is different from any other 8 engine I've seen and is the only intact (ish) one in the group. The sump has a wider girth than say, a Series 1, at the flywheel end and the oil drain-plug is at that end, rather than central.
The timing chain cover is an aluminium casting which incorporates the front engine mounts. The cylinder head is Series E and the oil filler tube is where it should be on an E, so it's not Series Z.
Any ideas, folks?
Ian |
Joined: 23 Nov 2007 Posts: 4766 Location: Swindon, Wilts.
Posted: Tue Nov 27, 2012 11:40 pm Post subject: |
Could it be one built for use in a boat?
Probably not as I have now looked at a picture of the vedette which is what they called the marine version, but it was also used as an APU for tanks which might have needed a different sump and front end. _________________ Bristols should always come in pairs.
welder
Posted: Tue Nov 27, 2012 11:55 pm Post subject: |
Penman wrote: | Hi
Probably not as I have now looked at a picture of the vedette which is what they called the marine version, but it was also used as an APU for tanks which might have needed a different sump and front end. |
Both of those thoughts have been entertained. Like you, I investigated the Vedette route and decided against.
Can't yet find suitable images of the APU's, or much in the way of information. I'll persevere. When I get ten minutes I'll whip the sump off, just to see if there are crankshaft balance webs which indicate Series E, as should be.
Ian |
welder
Posted: Fri Nov 30, 2012 9:46 pm Post subject: |
Sussed it! It's a bog standard Series E engine.
The E engine in my Series 1 is fitted with an earlier sump from a Series 1 as well as the Series 1 timing chain cover to enable front mounts to fit. As a result I've had no idea what an E engine looked like, as standard.
Well now I do cos I've got one Just got to strip it, make a good engine from the one fitted (cracked block) and the best components from the "new" one...and fit it. A doddle.
Ian |
welder
Posted: Wed Jan 16, 2013 10:07 pm Post subject: |
Ready for the Big Day!
Ian |
welder
Posted: Wed Jan 16, 2013 10:14 pm Post subject: |
Ta! I've just got my head round Photobucket so expect lots more pics!
Ian |
