Joined: 30 Apr 2013 Posts: 3848 Location: The Somerset Levels
Posted: Sun Mar 31, 2019 12:59 pm Post subject: |
Sunday morning down the yard, trying to correctly set the timing on the Commer lorry and also running the compressor up to give the 7 tyres some much needed air. _________________ Various Rootes Vehicles. |
Posted: Sun Mar 31, 2019 3:25 pm Post subject: |
Got the Singer of the ramps this morning, checked and topped up fluid levels and did the tyre pressures. Gave her a good wash and went out for a few miles.
Fantastic and always makes me smile.
Off to a meet at Whittington Castle next Sunday,hope the weather holds
Kev |
Joined: 25 May 2011 Posts: 2502 Location: South Cheshire
Posted: Sun Mar 31, 2019 6:10 pm Post subject: |
I've spent the last few days trying to re-arrange stuff in the shed to make things easier. I've got a long narrow shed, and have made things worse by putting shelves along the side to the extent that I can only just get the two cars alongside each other - which sounds great to anyone who has a single garage, but given the actual size of the place it shows how badly organised it is.
I decided I'd create a "bay" across the back, but I'd underestimated how long it was going to take. In itself this is weird as I did exactly the same a year or two ago, recall just how long it took, and how I told myself I'd never do it again.
Still, it's almost back to a point where I can actually get one of the cars out now. I was hoping that in moving a load of stuff I'd find things I could get rid of. So far, the tally is three tins of paint that are either empty or have solid paint in them. |
Posted: Sun Mar 31, 2019 7:52 pm Post subject: |
I’ve not attended before but my dad went last year.
As long as the weather holds it should be a nice local trip.
Kev |
![](images/avatars/4798399465480b471cc529.jpg)
Posted: Mon Apr 01, 2019 5:32 pm Post subject: |
I thought it would be a good idea to give "Trundles" (my 1930 Austin Swallow saloon) some exercise so today I set off for a drive around the local area. Everything seemed OK to begin with but after a while I started to get popping back through the carb and hesitation. After allowing the car ton idle for a couple of minutes it seemed fine again. Could this be a blocked jet? |
Posted: Tue Apr 02, 2019 11:18 am Post subject: |
Ray,
Quote: | Could this be a blocked jet? |
Or perhaps a sticky inlet valve??
Art |
Posted: Tue Apr 02, 2019 11:25 am Post subject: |
47Jag wrote: | Ray,
Art |
I did a compression test last night and they were all equal.
I suspect the 22FZ up draught carb because they are prone to crumbling away being made of Mazak. |
Posted: Tue Apr 02, 2019 9:03 pm Post subject: |
Found a bit of muck metal in the main jet of the carb (22FZB).
Hopefully I will have some happy motoring from now on - or at least until the next time.!
I have a bronze version of this carb which I am tempted to use but it is the exceptionally rare 22F (as opposed to the more common 22FZ) as used on the early Austin Sevens - so perhaps I could swap it for a more age appropriate one.? |
Mog
Posted: Thu Apr 04, 2019 7:55 am Post subject: |
Check and clean the fuel tank or you might have the problem again. |
Posted: Thu Apr 04, 2019 8:41 am Post subject: |
Mog wrote: | Check and clean the fuel tank or you might have the problem again. |
Forgive me for not explaining. The chip of Mazak was found ABOVE the jet so couldn't have come from the tank or any part of the carb before it. Unfortunately, these carbs have a habit of disintegrating which is why I am tempted to fit a bronze one.
As it happens, I have every confidence that the tank is clean. I have thoroughly restored and treated the tank with an ethanol proof sealant system called TAPOX. I have also made a foolproof filter that is hidden in the bottom of the carb. |
52classic
Posted: Thu Apr 04, 2019 7:50 pm Post subject: |
Now the clocks have changed we're officially on 'Summer Rules!' The Zodiac's diff came back from our Engineer friend and was put back in situ followed by a test run that proved all is now well at the rear. Pinion seal still leaking so we replaced that to finish the job.
Porsche has been off to the MOT station. Sadly the clevis for the new handbrake cable snapped on test! Re-engineered it today so it'll be MOT Monday for us.
With the 2 show cars ready for service, the F350 gets attention, fresh paint underneath and time to fit the doors which were refurbed during the winter.
Our party marquee is giving us good service to house the truck and to be quite a pleasant place to work. |
lowdrag
Posted: Sat Apr 06, 2019 5:22 am Post subject: |
Having come home using the starter and brakes having lost the clutch I shall be rebuilding the master cylinder this weekend having received the kit from Demon Tweeks. |
Posted: Sat Apr 06, 2019 8:34 am Post subject: |
lowdrag wrote: | Having come home using the starter and brakes having lost the clutch I shall be rebuilding the master cylinder this weekend having received the kit from Demon Tweeks. |
I remember that happened to me on Putney Bridge during the rush hour. !
Eventually, by the time I had got to my home in Woking, I had mastered the technique!! |
