Posted: Tue Mar 27, 2012 12:39 pm Post subject: Bad Vibrations |
Although this is a problem with the Stag, Its more general advice needed hence posting here..
I’m getting a really bad vibration on the Stag at any speed over 35mph when there is any form of acceleration, taking your foot off the accelerator and the vibration instantly goes, for this reason I suspect the problem is in the transmission rather than wheel balance?
The Stag is rear wheel drive with drive shafts from the diff that have UJ’s, would I be right in thinking that because the vibration is load related its more likely to be a worn joint, either on the prop or one of the drive shafts, than say prop shaft balance ?
Posted: Tue Mar 27, 2012 1:03 pm Post subject: |
I can't help with your specific question.
Does the prop have a centre support mounting/bearing? That could be playing up, the centre mounting on an old 7-Series I had needed replacing due to a vibration. I'd also be looking at engine and gearbox mounts too, my green E83W had a terrible shudder which was traced to a broken tie-rod that fits to the side of the gearbox and runs to the crossmember.
![](images/avatars/1471970806495e926f881e3.jpg)
Posted: Tue Mar 27, 2012 4:56 pm Post subject: |
Dave, your description of vibration under power and not on over-run is typical of a few failed needle rollers in Hardy Spicer type UJs. With some needle rollers missing or disintegrated the spigot will tend to displace any remaining ones to the non-drive side of the cups. Which throws the joint (and hence propshaft) out of balance under power but back into balance on the over-run when centred by the intact rollers.
Maybe if you tried driving everywhere backwards the symptoms would reverse themselves.
JIm. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
Joined: 26 Jan 2012 Posts: 1740 Location: Above the snow line in old Monmouthshire
Posted: Tue Mar 27, 2012 8:54 pm Post subject: |
Just out of interest, does this Stag have a manual box, or auto? |
Posted: Wed Mar 28, 2012 10:14 am Post subject: |
Thanks for the replies;
Rick, there is a quill joint between the propshaft and diff, this houses a single roller bearing and is a pain to remove, lots of dismantling
Jim, there are Hardy Spicer UJ's on the prop and the 2 drive shafts, I guess failure of any of these could be the cause? however they are all quite easy to change
Bitumen Boy, its a manual, curious as to why you ask?
Posted: Wed Mar 28, 2012 3:09 pm Post subject: |
Sheer nosiness really on my part but maybe some knowledgeable soul knows of a specific problem with either 'box. I'd start with the Hardy Spicers, particularly the driveshafts. I'm guessing they're not such vile instruments of torture as Herald ones... ![Twisted Evil](images/smiles/icon_twisted.gif) |
Posted: Wed Mar 28, 2012 7:16 pm Post subject: |
Bitumen Boy wrote: | Sheer nosiness really on my part but maybe some knowledgeable soul knows of a specific problem with either 'box. I'd start with the Hardy Spicers, particularly the driveshafts. I'm guessing they're not such vile instruments of torture as Herald ones... ![Twisted Evil](images/smiles/icon_twisted.gif) |
"vile instruments of torture"????
Fitting a repair kit to Hardy Spicer UJs is one of the easiest jobs on a car, except for the ones which are staked in. Difficulties are usally the result of tackling the job wrongly by pressing the cups inwards in a futile attempt at dismantling. The cups must be displaced outwards by supporting the shaft and tapping the yoke so that the cup comes outwards past the circlip groove.
Posted: Wed Mar 28, 2012 7:23 pm Post subject: |
Dave, levering with a bar (tyre lever?) between each cup (both sides) against the spider should reveal any wear fault in a UJ. Any movement at all shouts "scrap it or repair it".
Posted: Wed Mar 28, 2012 7:47 pm Post subject: |
Jim.Walker wrote: |
Fitting a repair kit to Hardy Spicer UJs is one of the easiest jobs on a car... |
In most applications, yes - but not Herald halfshafts. Everyone I've spoken to about them agrees it's a vile job, and having had my Herald long enough to have done most jobs, I'd sooner do pretty much anything else. It's such an unpleasant job that at least a couple of the Triumph specialists seem to do a reasonable trade in fully recon exchange units at getting on for £150 a side, when a HS kit is what - £10? If pushed for time - say you needed the car for work on Monday - I'd even say that's perhaps not too unreasonable (I reckon on a week each side to do the whole job, including the wheelbearing). And this is even considering that pulling that whole subassembly off the car isn't much fun either. Every car has (at least) one really nasty job, and on a Herald it's the halfshaft UJ's.
Still wouldn't sell it though and might even have another one day ![Smile](images/smiles/icon_smile.gif) |
Julian
Posted: Wed Mar 28, 2012 8:40 pm Post subject: |
I know this is a 'long-shot' but was it you I chatted with last summer in the McDonald's car-park on the Bath Road at Heathrow? A red rag-top I think...
Julian. |
Posted: Thu Mar 29, 2012 8:32 am Post subject: |
Bitumen Boy wrote: | Jim.Walker wrote: |
In most applications, yes - but not Herald halfshafts............
Removing/replacing the shaft from the car is a different issue. I was talking about over-hauling the joint.
Removing/replacing the do-nuts on MkII Vitesse Carden Shafts (half shafts do not have UJs) is a much more difficult and frequent job!
JohnDale
![](images/avatars/15744252225a79874427eef.jpg)
Posted: Thu Mar 29, 2012 12:21 pm Post subject: |
Hi Dave, Quill shaft bearing is not normally a major problem,only for oil leaks from the seal.
I would suggest Jim is right on the money with HS joints & it should be relatively easy to track down the culprit. One other thought comes to mind - rear engine mount(at the back of the gearbox) might be worth a look at,cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
Posted: Thu Mar 29, 2012 4:58 pm Post subject: |
Julian: Not me, yellow saloon, never been anywhere near/never want to go anywhere near Heathrow! Or McDonald's, come to think of it... Am I right in thinking you were talking uj's with this other guy?
Jim: Sorry, but I don't agree. Propshaft joints that can just be bunged in I don't have a problem with, but these little horrors are something else. Maybe if you had a good selection of the proper selective-thickness circlips - like half a dozen of each size - they wouldn't be too bad, but having to mess around with homemade shims (usually leading to cut fingers ) to eliminate the endfloat and ensure a quiet joint is a pain in the bum. Plus the shaft (I know halfshaft isn't technically correct, but it saves some people getting it mixed up with the prop), even without the hub and trunnion, manages to be both heavy and awkward to get hold of, as well as being predictably greasy and filthy. Removing the unit from the car is, of course, part and parcel of the job, if you can overhaul uj's in situ you should probably be using your superpowers towards some more productive end... ![Very Happy](images/smiles/icon_biggrin.gif) |
Julian
Posted: Thu Mar 29, 2012 8:42 pm Post subject: |
Bitumen Boy wrote: | Julian: Not me, yellow saloon, never been anywhere near/never want to go anywhere near Heathrow! Or McDonald's, come to think of it... Am I right in thinking you were talking uj's with this other guy?
I share your sentiments. I too was not wanting to be near McDonald's at Heathrow but I'm afraid work sometimes takes me there!
Julian. |
Posted: Fri Mar 30, 2012 12:27 pm Post subject: |
I'm not sure which would be worse, really - going to Heathrow but not McDonalds, or just going to a local McDonalds...
When I was still at school the beaks came up with a scheme, essentially to bribe the kids not to misbehave (or heckle them in assemblies, yes really!). Incidences of good conduct led to one being presented with a "merit slip", which chitties were then tallied up at the end of each week. The highest number of merit chitties earnt a "reward" - a Friday lunch of McDonalds burger and fries. This was fetched by one of the beaks from McDonalds on the other side of Cheltenham - at least 5 miles off, and the traffic in town meant it was always cold and greasy upon arrival, it never occured to them to take the winner into town and get it hot. For some reason, this was regarded almost universally as a wonderful treat! After once being the unlucky winner of this "prize", I was always careful to "lose" a proportion of the merit chitties I received (it didn't take any effort to pick them up) to make sure I never won again. I'm proud to say that I have never eaten any McFood since that day though I did almost get a McJob once but pulled out when I realised how much McBullshit I would have to put up with... ![Shocked](images/smiles/icon_eek.gif) |
