positive earth question.
PostPosted: Sun Dec 07, 2025 7:16 pm    Post subject: positive earth question. Reply with quote
My vacuum pump instructions only refer to a negative earth. As my car is positive earth, should I swap the wires to the pump motor?
Also what about the relay and switch?
I would greatly appreciate some help to avoid making an expensive error.
Please click on link for fitting instructions and diagram. Thank you.
https://www.carbuilder.com/cdn/shop/files/Vacuum_Pump_Instructions.pdf?v=17357643397575415403
PostPosted: Sun Dec 07, 2025 9:07 pm    Post subject: Reply with quote
All you need to do is reverse the pump connections, so the red pump wire goes to 5 and the black to 2. Everything thing else stays the same, unless the relay has a diode built in, in which case swap 1 & 2 (relay coil ) around.
PostPosted: Sun Dec 07, 2025 10:48 pm    Post subject: Reply with quote
Thanks Dave. That has really helped me. I don't see a diode symbol on the relay so I presume it is not there.
PostPosted: Wed Dec 10, 2025 3:17 pm    Post subject: Reply with quote
So I wired everything up as directed and...nothing. I found the 10 amp fuse had blown. What I don't know is if this happened before or after the "switch on". I can't go further at the moment as I have discovered the blade fuse is physically half the size of the ones I have.
PostPosted: Wed Dec 10, 2025 6:01 pm    Post subject: Reply with quote
Is the relay electronic ? Or definitely doesnt have a diode?
PostPosted: Wed Dec 10, 2025 7:32 pm    Post subject: Reply with quote
How would I find out, please?
PostPosted: Wed Dec 10, 2025 8:58 pm    Post subject: Reply with quote
Is there a part number on it? Or can you pop the cover off? Thinking about it, the last time I saw a relay with those terminal numbers it was an electronic delay relay used to hold vehicle internal lamps on for about 10 seconds after the door was closed. If it is an electronic device and has the incorrect power polarity, it could well explain why the fuse has blown, as would a simple diode across the coil, it is effectively a short circuit.
PostPosted: Thu Dec 11, 2025 12:00 am    Post subject: Reply with quote
So...would it be safe to swap 1 and 2 ?
PostPosted: Thu Dec 11, 2025 11:20 am    Post subject: Reply with quote
Do a simple continuity test between 1 & 2, then reverse the meter connections, if you get continuity one way but not the other then its a solid state device of some sort, either diode protected relay or a more complex electronic timer.
PostPosted: Thu Dec 11, 2025 12:37 pm    Post subject: Reply with quote
I have been to look at the relay. It has a number: 28146RE. If that helps?"
PostPosted: Thu Dec 11, 2025 1:04 pm    Post subject: Reply with quote
Hi Ray its a timer, that will have some solid state switching, this will be why the fuse blew, swap 1 & 2 round and it should resolve the problem.
PostPosted: Thu Dec 11, 2025 2:16 pm    Post subject: Reply with quote
Dave. Many, many thanks. Very Happy
PostPosted: Sat Dec 13, 2025 4:17 pm    Post subject: Reply with quote
Wires swapped over on the relay and a new 10 amp fuse fitted ...and still nothing.
The fuse has not blown.
I am at a loss to know what to do now! Sad
PostPosted: Sat Dec 13, 2025 5:21 pm    Post subject: Reply with quote
Is the pump insulated from the vehicle's ground? IE, is it completely insulated from the chassis, not touching any part of the vehicle with the pump body?
I'd be removing the pump itself, then seeing if it works away from the car, with those wires reversed?
In other words, it's possible the pump body and bracket are earthed to the pump, as it comes?
PostPosted: Sat Dec 13, 2025 9:47 pm    Post subject: Reply with quote
I have mounted the pump exactly as per the instructions. There are four securing screws holding rubber mounts to the chassis. Perhaps they could short the motor if it was not insulated ...but I would be surprised if it wasn't...and I expect Car Builder Solutions would have had complaints if the kit was no good.
