UKdave2002 Guest
Posted: Sat Feb 17, 2007 7:35 pm Post subject: |
I have learned much by my own mistakes... so am going to make a few more tomorrow!!
The b**stds allways snap flush
UKdave2002 Guest
Posted: Sat Feb 17, 2007 7:41 pm Post subject: |
Frost used to do some left hand drill bits, which were great for removing snapped studs often they would just undo as you drilled, don’t know about you but I hate using extractors cos I have had them snap too which compounds the problem
dave |
Posted: Sat Feb 17, 2007 8:04 pm Post subject: |
I've heard of easy-outs but never used one, they wind in and supposedly pull the stud out thanks to their reverse thread, the problem might be getting a hole started in the centre of the stud in which to put it
Like you I've used extractors when there's been a bit of stud to go at, but never really got on with them
Other options seem to include heat and possibly welding a nut onto the remains, if theres enough stud to get at.....
buzzy bee Guest
Posted: Sat Feb 17, 2007 8:19 pm Post subject: |
I have snapped a number of studs off in pumps and ag stuff! I used to do it on a regular basis as we used to use alot of air tools, and being rushed etc, it has to happen!
I used std extractors and drilled them out and helicoiled the hole. I to have never used easyouts but have heard that they too are a little snappy!
Welding a nut or a bolt, on sounds good if you can get onto it, but cover the head etc, for spatter.
buzzy bee Guest
Posted: Thu Mar 01, 2007 7:40 pm Post subject: |
Sounds good news, so it will be coming home under it's own steam then?
buzzy bee Guest
Posted: Tue Mar 13, 2007 10:13 pm Post subject: |
What a tedious thing to happen!! Oh well you will be good at doing head gaskets!!
Can't understand why it has justy started!
john-saab Guest
Posted: Sat Mar 24, 2007 9:42 am Post subject: |
For gawds sake don't snap the studs again...
Its a bit excessive but why not change all of the studs and then you will get an even load?..are new studs avaliable? |
