Riley Blue
Posted: Mon Apr 08, 2013 5:10 pm Post subject: |
| welshrover wrote: | | riley541 wrote: | | welshrover wrote: | creosote used to be a good one but you cant get it now with these elf and safety nuts  |
If it means more of the oil extracted from the ground goes to making petrol to keep our cars running rather than wood preservatives it gets a thumbs-up from me. It's also nice see fences in a variety of pretty colours too  | yes blue green and rot .. |
http://tinyurl.com/cfhmank |
Posted: Mon Apr 08, 2013 6:45 pm Post subject: |
| Any tractor even a little compact one with a winch and spade would do a good job. If you had better access, I might know of a engine with a winch, but that may need 15 or so ton coming onto your lawn... |
welshrover
Posted: Tue Apr 09, 2013 2:31 am Post subject: |
| riley541 wrote: | | welshrover wrote: | | riley541 wrote: | | welshrover wrote: | creosote used to be a good one but you cant get it now with these elf and safety nuts  |
lots of colours "and" rot
it doesn't work anywhere near as good as creosote did. these new water based paints look pretty for a while. but for a longer job creosote was better .I use old engine oil and creosote or this substitute stuff now .
water based fence paint .isn't it the water what we are trying to keep out ?
I use grease on the tops of the posts first then have covered that with a lead cap ..to keep the "WATER" out ,
it seems to work, my fence still looks like new after ten years and ive only painted it once in that time . |
Posted: Tue Apr 09, 2013 5:17 pm Post subject: |
I had to use a 3 tonne excavator to remove mine
 _________________ ROVER
One of Britain's Fine Cars |
bob2
Posted: Wed Apr 10, 2013 9:07 am Post subject: |
I did use water based for wood, but the basecoats were mixed with hardner rather than water and only the top coats were water based, its been well over 6 years now and the door is still as good as when I restored it!!
Its been well looked after though protected from excessive sun and also from rain most of the time! |
Joined: 23 Nov 2007 Posts: 4279 Location: South Cheshire
Posted: Wed Apr 10, 2013 4:06 pm Post subject: |
My dad used to work for BT / GPO; telephone poles are pine, treated once in a vacume with creosote and they last 25 to 50 years. There is a place near us that offers the same service, creosote can still be used commercially , all our fences and sheds have been treated this way; not the prettiest ! But should last!
Posted: Wed Apr 10, 2013 7:42 pm Post subject: |
Can't beat Creosote  |
Posted: Wed Apr 10, 2013 11:25 pm Post subject: |
Old engine oil is good..a bit messy..............but its not getting out the tree stump. _________________ The Clan Chieftain |
Posted: Wed Apr 10, 2013 11:46 pm Post subject: |
| buzzy bee wrote: | Can't beat Creosote  |
I wonder. I've successfully treated small areas like a shed door and the garage fascias (the cost would be prohibitive for a whole shed or fence) that have been previously creosoted with boiled linseed oil. It's really cut down on the maintenance needed in the wet Welsh climate leaving more time for more interesting jobs  |
Posted: Thu Apr 11, 2013 8:10 am Post subject: |
As always, we've all wandered wondrously off the original topic; but it's all useful stuff.
I have used a coloured, water-based product called "Cuprinol Garden Shades" for several years with great success. In fact, my entire timber-clad, house extension is coated in the stuff. It repels water like wax, it is available in a variety of bright and more subtle colours, it can be overcoated without sanding or other preparation, it doesn't seem to flake or fade, it penetrates the timber slightly, I think that it is much less harmful to health and the environment than creosote, it doesn't stink (although I know many people love the smell of creosote); but the downside is that it's fairly expensive.
The secret to keeping wood from decay is to allow ventilation and to give somewhere for water to run-off. In my experience, even softwood can get wet repeatedly without suffering so long as it can also dry easily.
This brings us full circle to the tree stump, because if the reverse can be engineered and the stump be kept fairly damp for an extended period it WILL rot more quickly.
As it happens, I also have a large tree-stump to remove. I will stick my kneck out and will post a photo later once I have removed it. |
Posted: Thu Apr 11, 2013 10:57 am Post subject: |
Green stumps are a problem, but a stump of a tree that has had a couple of years to start to dry can be 'stoved' out fairly easily. This was a method used by early settlers in Oz and I remember using it on our property when I was a lad, and have employed it in recent times too.
First excavate around the roots as far as practical, but remember you are only getting soil away from the roots, not trying to dig the thing out. Once some clearance has been made, build a fire in the excavation, and for this one might use bits of the stump or remains of the tree, or any available wood. Once the fire is going well, then carefully cover the stump, fire and all with turf and soil from the excavations, bringing in more soil from nearby if needed.
Keep well clear of the site and warn anyone that might wander about to keep clear. The fire will burn slowly for days, just like a charcoal burner's fire. The main stump will quietly burn away, as will most of the roots. That is one reason to keep clear, because the roots will burn underground many feet from the stump site.
Very large Eucalyptus tree stumps- say from a tree 6 feet in diameter, might take up to 10 days or a fortnight to burn away, small ones of 2 feet will be gone in 3 or 4 days. When gone, and allowing for the ground to cool down, the area can be ploughed with little problem. _________________ Dane- roverdriver but not a Viking. |
Posted: Thu Apr 11, 2013 1:17 pm Post subject: |
That's a brilliant explanation from Roverdriver and I may just try that with some smaller stumps from a few years ago. I have just come back into the house, slightly knackered after being as good as my word and trying my own method.
Stumped by peterthompson, on Flickr
It worked! I dug under and round it mainly using a drainage spade and took away about ten barrows of soil. In the course of that I severed some smaller roots and tried to under-cut the trunk as much as possible.
Finally, I took my sharp chainsaw with an almost worn chain and cut the buttress roots. I washed it all down with a hosepipe first to remove as much soil and grit as possible. It was tricky to get the main downwards root but with a bit of wiggling with the bar, out it came. Or rather, over it went. Now I have to make the huge lump a little lighter and remove the trailing roots that are everywhere. UPDATE. NOW DONE.SEE BELOW
_JAN1642.JPG1292768256 by peterthompson, on Flickr
I feel quite proud of it though and no vehicle was harmed or strained. |
Mog
Posted: Sat Apr 13, 2013 3:12 am Post subject: |
| ukdave, you just need to dig a bigger hole to find out what is holding it. Hope you have got it out by now. |
Uncle Alec
Posted: Sat Apr 13, 2013 11:21 am Post subject: |
Boys, boys, boys - you're a disgrace to the old car repairing fraternity.
Spray some WD40 onto it, leave it a couple of days, then just gently tug it out. |
Posted: Sat Apr 13, 2013 11:54 am Post subject: |
File a couple of flats on it and use your biggest spanner?  |
