Preselect gearbox rebuild
Goto page Previous  1, 2
petelang
PostPosted: Fri Apr 22, 2022 8:13 pm    Post subject: Reply with quote
Yes Ray, had to make some adjustment when I first got the car. That though was due to slip so, although reverse clearly selected, it barely drove. The adjustment cured that but the later problem is that nothing selects in reverse, despite pumping the pedal full stroke repeatedly, then suddenly, bang it goes in.
What is unusual compared to Daimler or Lanchester is this has no fluid coupling so 1st and reverse have to be slip engaged so they are subject to more wear. The reverse set up is not like the forward adjusters which have the cam and spring arrangement. Its not like anything I have read about so not entirely clear how to adjust it.
Daimler V8 250 1969
PostPosted: Fri Apr 22, 2022 9:03 pm    Post subject: Reply with quote
...and I thought I had problems! Rolling Eyes
PostPosted: Mon Apr 25, 2022 9:45 pm    Post subject: Reply with quote
Thanks for explaining, Pete.
It seems you need a means of rotating the box to see if the pumps are (both?) working and if the selector mechanism is O.K. I wonder if a stationary engine would do the trick.?
They used to be cheap as chips at one time but now they are being collected I don't suppose they still are.
I suppose you could start by attaching the pedal and seeing if it does anything. Does the pedal hydraulically pressurise the oil?
By chance the other day I came across some photos of someone conducting a crude (but seemingly effective) test on an overdrive gearbox sitting on the garage floor with nothing more sophisticated than a power drill on the input shaft and a couple of wires to a battery to energise the solenoid on the o/d. The drill wasn't a massive thing either but I guess some sort of adaptor was needed (although it wasn't visible) to mate the drill chuck to the input shaft of the gearbox - I can't see the standard chuck being large enough.
petelang
PostPosted: Wed Jun 10, 2026 4:59 pm    Post subject: Reply with quote
My word, here we are now Four Years later, I'm revisiting this post because I have just got round to stripping the spare gearbox subject of this post.
It's a good job I did because, although it looked in jolly good order through the big hole in the top, all was not at all good in the geartrain. Its had a catastrophic failure of the planet gears in the first gear drum, a similar, but less extent in the second gear planets. There were actually virtually no teeth left on the first gear set.
But, it had a brand new set in Reverse gear!
Four years to drum up the courage to dismantle it!
I still also have the problem on the other car which doesn't like selecting reverse when sat on an incline.
Nobody has ever been able to explain this so I figured, there's only one way to find out and ripping open the spare box might help me understand the full workings of it.
There is an extremely useful book that gives a step by step strip and rebuild procedure, by Peter Banjo Myers which I recently acquired, but having stripped this one there are vast differences and a lot of unanswered questions have arisen.
Good job I'm not in a hurry!
Daimler V8 250 1969
Page 2 of 2
