Voltage drop problem.
Vintage Fly Guy
PostPosted: Thu Apr 10, 2025 10:00 pm    Post subject: Reply with quote
It took the electrician a full two hours but Carl has found the source of the battery drain. He removed all the fuses (about 50) and checked to no avail. He then noticed two extraneous fuses tucked down beside the battery which were for the LPG conversion; a 2 amp fuse showed a significant drain .
To be honest, I had completely forgotten about the LPG. There is a faulty module in the system that was causing the problem. I cannot get LPG anymore so it's disablement is not a problem.
I am greatly relieved but 150 quid down. Very Happy
I would not have found the leak as I had been looking in the wrong place.
Glad you've (hopefully) got it sorted. LPG conversions on Rover V8 engined cars were the work of the devil... second only to an aftermarket diesel engine conversion; which, as history and classic car values have clearly shown, was roughly equivalent to volunteering for a frontal lobotomy!
PostPosted: Fri Apr 11, 2025 9:27 am    Post subject: Reply with quote
I do not get the hate for the LPG used as car fuel.
About 35 years ago I installed my first system into my Triumph 2000 Mk2. This made it possible for me to use that car as a daily driver because the price of LPG per litre was so much lower compared to petrol. It still is. After the Mk2, I installed a system in my Mk1, an Austin Westminster A110, then a Jaguar 420, a Triumph 2500 Mk2, a Citroen Xantia (I bought that one with the LPG system installed already, only kept if for less than a year), a 2 door Range Rover and a Jensen Interceptor.
In all these cars the LPG system worked flawless. Engines seem to run even smoother (Triumph, Jaguar, Austin) than on twin carburettors.
There are negatives: loss of space because of having an extra tank, and slightly worse performance. Loss of performance never was a big issue for me because the cars I selected usually had enough performance. Those two negatives are the reason I feel LPG is best suited for larger cars with big(ger) engines.
A couple of things that needs care: ignition timing should be adjusted a little, another grade of spark plugs, exhaust valves will burn into the cylinder head if you drive a lot (but getting this fixed is fairly cheap). Adjustments to the system is easy. The electrical side also is simple.
Where it gets difficult is when newer type of cars are fitted with LPG. By that I mean the ones with fuel injection and computerized engine management systems. I have never installed those, and was not a fan of the system in the Xantia.
PostPosted: Fri Apr 11, 2025 10:20 am    Post subject: Reply with quote
It is my understanding that in this country if you wanted to install an LPG system in a later car with fuel injection ( I can't remember the exact cut off date) you need to be qualified.
I remember in an episode of 'Wheeler Dealers'; Ed China had to hand a Range Rover conversion over to an LPG specialist, ostensibly for this reason. I think it is similar situation to air conditioning but I am not sure about that.
PostPosted: Fri Apr 11, 2025 10:40 am    Post subject: Reply with quote
I'd imagine that its governed by the same regulations as any other Gas appliance would be in the UK?
PostPosted: Fri Apr 11, 2025 11:08 am    Post subject: Reply with quote
LPG was the viable alternative fuel once genuine 5 star petrol ceased to be sold [octane rating being the important issue]
A local fella ran an Aston Martin V8 some decades ago, a car which shouldn't have been run on anything less than 100 octane fuel[ which LPG is, IIRC?}
Also until Dacia [AKA Renault] discovered folk were prepared to pay out an awful lot more dosh for a new car, providing they thought it was the cheapest & best available....they offered a dual fuel Sandero...with a dugnut gas tank in the boot where the spare wheel would have been.
PostPosted: Fri Apr 11, 2025 12:04 pm    Post subject: Reply with quote
We had a duel fuel Vauxhall Astra for a time. It was quite a popular option at one time but it seems to have lost it's appeal...
PostPosted: Fri Apr 11, 2025 12:49 pm    Post subject: Reply with quote
I am in the Netherlands and these older type of self built LPG systems needs to be checked by the authority (RDW). That was never a problem.
No such things for air conditioning, they need no check. In the past I have installed air con system in classic cars.
Both LPG and air conditioning are all fairly simple add-on systems.
V8 Nutter
PostPosted: Fri Apr 11, 2025 4:10 pm    Post subject: Reply with quote
A friend of mine imported a Cadillac from Belgium, it was fitted with an LPG system. After a couple of years his insurance company said it would need to be checked by an expert and it would need some sort of safety certificate. Of course no experts were interested in certifying a foreign system and he took it off. A good thing really because it was very unreliable.
PostPosted: Fri Apr 11, 2025 4:45 pm    Post subject: Reply with quote
I find the engine runs sweeter on LPG. IT may have something to do with the fact that I fitted spark plugs with a silver electrode. The downside is that they have a shorter life span than conventional plugs.
With all this hoo hah over vehicle emissions I would have thought LPG would be the ideal compromise as not everyone either wants or can afford a new electric car. The emissions from LPG cars are so low that they are exempted from that part of the M.O.T.
PostPosted: Fri Apr 11, 2025 7:00 pm    Post subject: Reply with quote
Exactly that. There are no valid reasons why LPG was not promoted more. Quite the contrary, you would think it would be better regarding emissions etc. In the Netherlands this is happening as well, it is a dying option. A local LPG expert here is closing down his shop, not enough business anymore. The high times were in the 80s and 90s.
PostPosted: Fri Apr 11, 2025 8:01 pm    Post subject: Reply with quote
If I have a grump it is that we were all encouraged to get our "gas guzzlers" converted to L.P.G. and to that end I entrusted my pride and joy to a professional outfit who did a first rate job..but then you would expect that for 2K pounds (and that was 15 years ago!!).
I will now find it virtually impossible to get someone to buy the car... so a double whammy!
Vintage Fly Guy
PostPosted: Fri Apr 11, 2025 10:33 pm    Post subject: Reply with quote
When LPG was all the rage 2,000 quid bought a lot of petrol. Still, people thought it was a great idea to pay that lump sum out to be drip fed a return when filling the car up each week.
It's a bit like solar panels these days, it will most likely take 15 to 20 years to get your initial outlay back, and by that time something (most likely the invertor and/or battery bank) will have packed up and needed replacing, adding further to the cost, so if you're lucky you might just about break even before the whole lot needs replacing!
Back to cars... Roll on 20+ years and those cars from the 'LPG era' have started to achieve 'classic car status'... but, as they've been modified, they aren't worth anything like what an unmodified 'factory original spec' car is worth. Hence my initial comment about LPG conversions (with the benefit of hindsight) being the work of the devil where classic cars are concerned.
Never mind, perhaps they'll be a good candidate for conversion to EV? I'll get my coat! Laughing Wink
PostPosted: Fri Apr 11, 2025 10:56 pm    Post subject: Reply with quote
The way my car works is that it has to start on petrol. When the optum temperature is reached it automatically switches over to LPG. If the LPG runs out the car will just run on petrol; which is the situation now.
The conversion provided for a discreet filler cap built into the rear bumper; very neat! and a doughnut gas tank in place of the spare wheel.
A sophisticated electronic splice into the pre existing system has ensured that my car has been reliable but it has required a regular check up with the boffins who would take the car out with test equipment attached.
Said boffins have now closed down; as has our local auto electrician (lured to Aston Martin Rolling Eyes )
Not good for us locals.
PostPosted: Sat Apr 12, 2025 6:26 am    Post subject: Reply with quote
I had a Vauxhall Omega converted to LPG in 2000 by a firm in Crewe, the conversion cost around a grand and I calculated that payback time was at about 25000 miles, or about 9 months given my annual mileage in those days.
Although the car was EFI, the conversion used the simpler lpg mixer, and wasn't connected to the car's engine management system, you had to switch from petrol to lpg manually when the engine had warmed up a bit. Occasionally if the switch to lpg was made to quickly the engine management lamp would come on, because the O2 sensor would be expecting a richer mixture!
I did around 150,000 miles in the car, so the conversation cost was recovered several times. When I sold the car , I removed the LPG equipment as I figured that an aftermarket conversion would't add any value, and sold the LPG bits for a couple of hundred.
The only downside of running on LPG was the more frequent change of plugs, HT leads and a couple of coil packs.
PostPosted: Sun Apr 13, 2025 5:51 pm    Post subject: Reply with quote
With the older LPG systems - the ones I always used - it is easy to remove all the LPG stuff. An hour or two of unscrewing things. You might end up with the hole for the filler though. I cannot see that will depreciate the value of a car much (you can always weld it up, and anyway most fillers are not directly mounted in a rear wing or such so it is not much of a problem anyway).
Page 2 of 3
