Posted: Sun May 11, 2025 3:44 pm Post subject: |
| alastairq wrote: | | I believe there were some engines where one did the tappets whilst the engine was running! So, never mind scorching the fingers........ |
Yes. That is true. I tried it once but found the results unsatisfactory. The trick is to remove the feeler gauge quickly so as not to get it trapped...and ruined! |
Rusty
Joined: 10 Feb 2009 Posts: 317 Location: Bunbury, Western Australia
Posted: Mon May 12, 2025 1:03 am Post subject: |
| Old BMC/Leyland A, B and C series engines used to be done with the engine running, as instructed by the factory, I was trained in a Leyland workshop, and all tappets (except for those done cold in an engine rebuild) were done "hot" with the engine running, and rebuilt engines had the tappets "re done running" after the head had been re tensioned after being heated up to operating temperature. After you have done them a few times, it's not hard, I still do them this way. |
Joined: 23 Nov 2007 Posts: 4442 Location: South Cheshire
Posted: Mon May 12, 2025 9:02 am Post subject: |
We could have a similar debate with tyre pressure's, they change with both temperature and altitude.
If you set your tyre pressure in Buxton on a hot summer day , then drove to the coast which by freak of UK weather was near freezing, the tyre pressures would now be around 5psi lower..... |
Posted: Mon May 12, 2025 9:57 am Post subject: |
...and I was wondering if anyone would have anything to say about this sort of stuff...??
It would seem there is plenty to discuss.
Maybe someone knows why older Riley engines are so clattery? They are all like it ...which surprises me, as they have short push rods, which require closer tappet clearances.
What I am unsure about is how a cam profile can affect the tappet clearances.? |
Posted: Mon May 12, 2025 9:25 pm Post subject: |
A friend of mine had a fleet of six or seven 2.5 litre Riley RMs that he used for wedding hire and I can certainly confirm that they were all very clattery.
Posted: Fri Aug 15, 2025 10:22 am Post subject: |
Just out of curiosity, I looked up the tappet clearances for a Bristol 2 litre engine. (The aerodyne cars have always been a favourite and high on my wish list) and found that they should be adjusted cold...but get this... clearance is only 0.002". What is even more surprising is that it applies to both inlet AND exhaust.!
These wonderful engines are, of course, rather sophisticated and nothing would surprise me when it comes to Bristol (with pre War BMW origins).!
https://bristoloda.org/wp-content/uploads/2013/01/400-manual-Section-1-Engine-Exhaust.pdf |
Miken
Posted: Sat Aug 16, 2025 2:04 pm Post subject: |
| Ray White wrote: | Just out of curiosity, I looked up the tappet clearances for a Bristol 2 litre engine. (The aerodyne cars have always been a favourite and high on my wish list) and found that they should be adjusted cold...but get this... clearance is only 0.002". What is even more surprising is that it applies to both inlet AND exhaust.!
I seem to recall that on my 1959 Royal Enfield 350 (iron head), the clearances were zero &zero. I think I used to give the exhaust a touch of clearance to be on the safe side. |
Posted: Sat Aug 16, 2025 2:49 pm Post subject: |
I can't remember the clearances, but some, or maybe, all the OHV mid 30's Vauxhalls were supposed to be adjusted dynamically (while the engine was ticking over) definitely a 3 handed job. _________________ Bristols should always come in pairs.
Joined: 14 Oct 2016 Posts: 2281 Location: East Yorkshire
Posted: Sat Aug 16, 2025 3:02 pm Post subject: |
On the Ford small sidevalve engines [1172cc]...8 & 10HP types, there are no tappets [from the factory]....clearances being set by either mixing & matching cam followers, or taking a smidgen off the foot of a valve stem.
The Buckler Register ....whose prides n joie often used Ford sidevalve power....has an article in their bulletin describing how it was best to measure and adjust valve clearances using a dial indicator, with the head off[or was it, orff with his head???]...
That way, bearing in mind the minimum required clearance, the required amount of valve lift was to be aimed for....which may or may not result in the expected Ford method of setting the clearance values..to be differed from. Subject to the minimum clearances as noted above.
Might make the valve train a tad rattly, but the main thing was achieving the intended valve lift values.
Side valves, of course. _________________ Dellow Mk2, 1951 built, reg 1952.
