Kaybee
Joined: 27 Dec 2007 Posts: 147 Location: Croydon, Victoria, Australia
Posted: Thu May 08, 2008 12:09 pm Post subject: |
a '26 Garford 3 ton delivery van, had just rebuilt the sleeve valve engine and gave it a short run...discovered that rear wheel only brakes on a 3 tonner are interesting.... ..and while I was working at the same place, a couple of 12/40 Alvis's. _________________ If it's old...it's good ! |
Scotty
Posted: Thu May 08, 2008 5:27 pm Post subject: |
| Kaybee wrote: | a '26 Garford 3 ton delivery van, had just rebuilt the sleeve valve engine and gave it a short run...discovered that rear wheel only brakes on a 3 tonner are interesting.... ..and while I was working at the same place, a couple of 12/40 Alvis's. |
Kaybee - may I ask, was it a double or single sleeve-valve engine?
I have an interest in these engines and have yet to hear either type running. From contemporary advertising of the period manufacturers boasted they "are almost silent" and I've always wondered if that was in comparison the chattery old external mechanismed side-valves of the time, where in actual fact were noisy themselves, however less so than the side-valves.
Scotty.  |
old gto
Joined: 10 Dec 2007 Posts: 172 Location: Orlando, Florida
Posted: Sun May 11, 2008 1:42 am Post subject: |
I got to drive our 1931 Chevy a bit before we found the termites, and started tearing it down for re-build. _________________ "The only thing I`m sure of.....is that I`m not sure of anything!" |
Kaybee
Posted: Sun May 11, 2008 1:02 pm Post subject: |
| Scotty wrote: |
Scotty.  |
Hiya Scotty, it was a double sleeve,Knight Patent design. It was reasonably quiet for a commercial engine of that period, but it had an Alloy crankcase that was solid mounted to the frame, so that may have made some contibution to the noise factor. It did run very well and seemed quite strong on the road. Later on I had a friend with a later Willys Knight, it was a high mileage unrestored car and it smoked like a chimney but was very quiet in the engine, so maybe there was something in their claims, cheers, Col. _________________ If it's old...it's good ! |
Posted: Sun May 11, 2008 6:26 pm Post subject: |
Mine was '34 Austin Ten, it was 25 years old when I learned to drive, and passed my test, in it.
Cost my father £10:10s as a non-runner on which we did a top overhaul using "The Book Of The Austin Ten" borrowed from the library.
Later on we also did the big ends (scraped in white metal) and piston rings, it was also resprayed out of doors using one of those cylinder vacuum cleaner spray guns and household gloss paint whose name escapes me but I think it started with VAL. |
Posted: Sun May 11, 2008 6:33 pm Post subject: |
Valspar! They used to have an advert showing boiling water from a kettle being poured over the top of a table... though why anyone should paint their table with it escaped me. Ideal for painting engines with though.  |
Posted: Sun May 11, 2008 9:21 pm Post subject: |
| Valspar, of course, that's the one. |
